[ICEM] gas turbine Combustion chamber
Old   April 21, 2013, 07:56
Default gas turbine Combustion chamber
Ananthakrishnan.A.S
Ananthakrishnan is on a distinguished road
Send a message via Skype™ to Ananthakrishnan
Hi everybody,
I am trying to mesh a combustion chamber (using unstructured mesh). I have attached the geometry file and the mesh i created for the combustion chamber of a gas turbine engine in the dropbox link below. Can someone please have a look and let me know whether its good or not!!! i will be really thankful.
https://www.dropbox.com/sh/jes8accs86nu0ai/QP3arwI26S
As i am new to unstructured meshing i dont know all the facilities available in ICEM.. If possible, please give some alternate ideas about how to proceed with this. I am trying only unstructured mesh as I think structured mesh would be very difficult for this geometry..
Thank you very much
Ananthakrishnan is offline   Reply With Quote
Old   April 22, 2013, 16:54
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
hey there, you mesh is not smoothed. possibly interrupted because of holes in the geometry, have you done build topology ??? i can assist you meshing this...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 22, 2013, 16:59
diamondx's Avatar
Ghazlani M. Ali
let me know if you still need help with it
Regards,
Ali
Old   April 22, 2013, 18:46
Ananthakrishnan.A.S
hi,
thanks a lot for your reply. I would be really thankful if you can continue assisting me with this..i did build topology while creating the "body (fluid)"..
After few trials, i was later able to get hold of the meshing procedure. https://www.dropbox.com/sh/jes8accs86nu0ai/QP3arwI26SI have also sent the dropbox link directly to you( i already had your email id). This is the procedure which i followed
1.build topology
2.create parts with whatever things you need to control the mesh separately
3.give proper values for element size in part mesh setup
4.create surface mesh using triangular elements (earlier link contained tetra. I feel triangular elements can follow the geometry better).
5.create volume mesh without using the surface mesh (if i create vol mesh using the surface mesh, the vol mesh goes outside the domain, i dont know why!!!!)
current problems...
1.not all the holes follow my part mesh setup size (two holes are meshed with bigger elements which do not follow the curved geometry)
Doubts
1.what is the best manner to create the volume mesh. is the one which i explained above sufficient or are there better ways to do it!!!
2.should i improve the surface mesh as much as possible before proceeding to volume mesh (i my case its not useful because, if i use the surface mesh to create vol mesh it goes outside)
Thank you very much!!
Old   April 23, 2013, 11:53
diamondx's Avatar
Ghazlani M. Ali
the steps you followed are good.
as a start, directly compute the volume mesh (octree method)
see if your curves node distribution is respected.
then generate your delaunay, you don't need to erase anything...
Regards,
Ali
Old   April 23, 2013, 11:55
diamondx's Avatar
Ghazlani M. Ali
in the project that you shared, i don't see the curves in a special part... you must have missed some of them, that is why it does not respect them.
Regards,
Ali
Old   April 24, 2013, 10:42
Ananthakrishnan.A.S
thanks for the help..i added the rest of the parts which were missing and the mesh was better.
i then tried delauney mesh but the mesh becomes something like in the picture attached..It was good with octree method though..
Old   April 24, 2013, 12:07
diamondx's Avatar
Ghazlani M. Ali
you can'T generate a delaunay without a surface mesh. you have to generate an octree mesh , then switch to delaunay.
Regards,
Ali
Old   April 24, 2013, 12:41
Ananthakrishnan.A.S
Yes i did that
1.create volume mesh directly using octree.
2.create volume mesh again through quick delauney with volume part name as "inherited" and input as "existing mesh"
thanks
Old   April 29, 2013, 17:28
diamondx's Avatar
Ghazlani M. Ali
ananthakrishnan,
Are you injecting kerosene in your chamber ??
Regards,
Ali
Old   April 29, 2013, 17:35
Ananthakrishnan.A.S
yes.
Old   April 29, 2013, 17:36
diamondx's Avatar
Ghazlani M. Ali
have you started yet ???
Regards,
Ali
Old   April 29, 2013, 17:45
Ananthakrishnan.A.S
yes, i have but i am still working on the mesh simultaneously. I want to improve it
Old   August 5, 2014, 08:55
Gürkan Sarikaya
gurkan is on a distinguished road
hi guys, i have a problem with same situaton and I am already newbie for meshing a volume. so could you please help me to prepare meshing a annular combustion chamber, do you have a video or something like tutorial to solve my problem. or could you please how can i start and what procedure do i have to follow? i am preciate for your help. also i thought i have to make 3d mesh for that situation and if i explain my problem a little bit;
i will use fluent to solve flow characteristic inside the flametube and annular tube. but first i have to mesh my combustion chamber volume.
i have already flow volume, i mean i divide my combustion chamber volume by two part those are flametube volume and outside of the combustion chamber which is annular tube.
please help me, at least for making mesh to this problem.
gurkan is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
boundary condition at the outlet of a gas turbine combustion chamber sharifi FLUENT 1 November 14, 2012 11:57
CFD Analysis - Combustion in Gas Turbine Engine juzer_700 Main CFD Forum 0 April 19, 2012 03:10
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
