April 18, 2013, 16:53 |
ICEM Cfd Aspect Ratio
Rep Power: 13 |
Hey,
Do you have any tips how to set the growth rate, when using block mesh? I need smooth tranisiton between cells in the picutre. Mike Last edited by diamondx; April 18, 2013 at 19:59. |
April 19, 2013, 00:48 |
go to pre mesh parameters > Match edges
For growth rate (to resolve viscous effect) you need to provide first cell height, meshing law, growth rate in edge mesh parameters. |
April 19, 2013, 14:07 |
venki
Rep Power: 15 |
You have do proper mesh distribution.
April 19, 2013, 16:10 |
Rep Power: 13 |
Thank you very much guys. With Far's tip I solved the problem.
Best regards, Mike |
aspect ratio, icem cfd |
Learn ANSYS ICEM CFD | easy_astronaut | ANSYS | 2 | December 15, 2013 16:34 |
[ICEM] Aspect ratio vs quality of a tetra mesh | vmlxb6 | ANSYS Meshing & Geometry | 5 | September 25, 2012 14:21 |
Grid Aspect Ratio | harishameed33 | Main CFD Forum | 1 | August 11, 2012 23:35 |
[ICEM] check aspect ratio | camoesas | ANSYS Meshing & Geometry | 2 | November 14, 2011 10:38 |
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent | ivanddd | ANSYS Meshing & Geometry | 1 | February 3, 2011 01:51 |
