[GAMBIT] mesh generation for porous meia with Gambit |
April 12, 2013, 09:37 |
Abed
Rep Power: 14 |
Hello
Would somebody please help ? I truely appreciate your comments. I need to generate an unstructure mesh for a porous media using Gambit mesh generator. All I have is the coordinates of the circular pores and their diameters. For my CFD project I have to produce a neutral grid file (*.neu file) using Gmabit mesh generator. Any comments on how to do this will be highly apprecited. Abed |
April 19, 2013, 05:25 |
Maxime Perelli
Rep Power: 41 |
What do you mean with porous media?
In Gambit you can set a volume as porous media, but this is for later set up in Fluent. On the other hand you could model and mesh your media, if it is not so complex. Do you have a sketch on your geometry?
In memory of my friend Hervé: CFD engineer & freerider |
April 20, 2013, 09:34 |
Abed
Rep Power: 14 |
Thanks for the reply,
I have written my own fluid simulator, so I am not using Fluent. But I have to use Gambit to generate an unstructured mesh made of triangular elemets (in 2D space). My code then reads the *.neu file produced by Gambit and starts the simulation. I do have the geometry which is defined by a data file that contains the coordinates of the circular pores and their radii. I am trying to find an easy way to have Gambit read the data file and to make it understant the geometry. |
April 22, 2013, 02:15 |
Maxime Perelli
Rep Power: 41 |
do you have a sketch of your model you want to built?
Else you can try using the import Vertex Data Files option http://aerojet.engr.ucdavis.edu/gamb...t_vertex_using
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
ANSYS's MESH GENERATION FUNCTION vs Gambit | sanlee39 | FLUENT | 2 | April 8, 2013 07:07 |
[ANSYS Meshing] Question about mesh generation learning | lnk | ANSYS Meshing & Geometry | 2 | July 7, 2012 07:45 |
ISAAC code mesh generation | morteza08 | Main CFD Forum | 0 | June 15, 2012 10:26 |
