[GAMBIT] Error: small gap in meshing with Tgrid
Old   April 12, 2013, 03:18
Default Error: small gap in meshing with Tgrid
I Gusti Gde Badrawada
gdebadrawada is on a distinguished road
Hi... I am a beginner in Gambit. I want to ask about meshing process.
I mesh a volume that has a small volume in it. I have succeed for meshing the small volume, then I want to mesh the bigger one with Hybrid-Tgrid type. But I have not succeed with Gambit comment: Error: small gap.
Thank for helping
gdebadrawada is offline   Reply With Quote
Old   April 19, 2013, 05:21
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
first I assume you need to substract (or split) smaller volume from first.
Regarding small gap, it means that you have a small edge inside your volume, and gambit cannot mesh this entity.
For fixing this problem, you can use merge or refine your mesh on this entity.
As usual a picture may help
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
[snappyHexMesh] Meshing a small gap between walls staustrahltriebwerk OpenFOAM Meshing & Mesh Conversion 1 July 23, 2012 12:46
BL meshing airfoil with gap ghost FLUENT 18 December 1, 2009 23:47
using Tgrid meshing from gambit with FIdap philippe FLUENT 0 September 30, 2008 04:50
Tgrid meshing around cylinders in GAMBIT Chris FLUENT 3 March 5, 2003 08:43
TGRID & Meshing Eric FLUENT 3 February 13, 2002 11:52
