[Workbench] Overlapping zone
Old   April 5, 2013, 00:57
Question Overlapping zone
Lagunesvary
chinna is on a distinguished road
Hai, I`m using Ansys 14.0 Fluent to simulate heat transfer in heat exchanger. I wanted to use Dual Cell Model. However I`m failing to create overlapping zone between the 2 domains(internal fluid and external fluid). I found there a way to create overlapping core on meshing stage but I couldn`t find a guide. Can anyone help me with this..??
chinna is offline   Reply With Quote
Old   April 5, 2013, 07:25
Paritosh Vasava
vasava will become famous soon enough
Do you mean the interface between solid and fluid domains?
vasava is offline   Reply With Quote
Old   April 6, 2013, 02:32
Lagunesvary
yes. i thought if possible i just want to create an imaginary layer using shell conduction.
from inside it would be: hot water > tube > cold water > shell
overlapping interfaces
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 02:47
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
