[ANSYS Meshing] how to mesh this geometry
Old   April 1, 2013, 13:46
Default how to mesh this geometry
Constantine (Gus) Gkikas
gus.gkikas is on a distinguished road
I am working on this attached geometry ,and my goal is to set up an Fluid Flow(cfx) on Workbench,but a I'm having problems with the mesh.
Can you help me with some guidelines and ideas for methods to use?
Thanks in advance
Konstantine
gus.gkikas is offline   Reply With Quote
Old   April 1, 2013, 14:19
Astio Lamar
asal is on a distinguished road
Hi!
http://www.youtube.com/watch?v=mgjRT4WY_iA
You can find more with the same geometry.
asal is offline   Reply With Quote
Old   April 2, 2013, 06:48
Thanks a lot asal,but I don't know anything about meshing at the ICEM.
I have tried meshing the geometry at Ansys Meshing Application and those are my results
I think,they are very bad...
How can I improve that mesh?
Thanks in advance
Old   April 2, 2013, 07:06
Mohammed
Mohd123 is on a distinguished road
Inflation is a must and ofcourse to have fined mesh at inlet and outlet of the airfoil.
Boundary layer as fine as possible for accurate results.
Mohd123 is offline   Reply With Quote
Old   April 2, 2013, 08:36
Astio Lamar
Hi!
You should employ some inflation layer (Prism) around the airfoil. Moreover by using some mesh controls refine the mesh at the rear side of the airfoil to be able to capture the flow in this area.
Old   April 2, 2013, 09:35
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
do you need tutorials for ansys ? i can provide them for you
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 2, 2013, 09:38
Thank you for your answers guys...!
I will do the proper changes and i will post the results...
Diamondx...I have already the tutorials which included at the ansys...
Old   April 3, 2013, 13:53
Hello!!
I believe I have done the proper changes!
What is your opinion??
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
[Workbench] Meshing and export mesh from STL geometry alerfreire ANSYS Meshing & Geometry 0 March 26, 2013 10:25
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
