[Workbench] 2D Aerofoil Mesh in Workbench
Old   March 29, 2017, 01:08
Tashefa S
Tashefa S is on a distinguished road
Originally Posted by arshiya4 View Post
Martyn,
Make sure you pick 5 faces and not 4. Since your airfoil is not symmetric, its curved section on the bottom makes the 5th face with the horizontal axis. Once you pick the 5th face, you will be able to mesh using the rest of the tutorial.
Hope this helps
Arshiya
I'm a beginner and facing the same problems, how do I pick 5 faces instead of 4?
Tashefa S is offline   Reply With Quote
Old   September 24, 2017, 16:56
Prakash Jha
prakashjha is on a distinguished road
Martyn,
Hope this helps
Arshiya
Hi
Can you please elaborate the 5 faces? I am facing exactly the same problem and stuck badly
Thanks in advance
Regards
Prakash
prakashjha is offline   Reply With Quote
Old   June 16, 2021, 18:20
Default Symmetric airfoil meshing problem
  #23
Mubshar usman
Malik9477 is on a distinguished road
Actually i am working on symmetric airfoil meshing. But when i set leading edge square, then trailing edge mesh does not remain square. I applied biasing and also i did work with no biasing. But i could not get my mesh element square.
Kindly someone tell me that how can i improve mesh and how to make 1st cell as square
Malik9477 is offline   Reply With Quote
Old   March 7, 2022, 18:24
jose daniel
hoyos98 is on a distinguished road
I suggest you visit https://aeroptimal.com/mesh (you must create an account to use this module), where you can create a full structured airfoil mesh - https://youtu.be/4Opu0zk7gFk . You can export .su2 .msh .foam .vtk
hoyos98 is offline   Reply With Quote
airfoil mesh, ansys 13 work bench
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
