[ICEM] [problem] ICEM Scripting Loop to create points and Curves
Old   March 25, 2013, 07:02
Default [problem] ICEM Scripting Loop to create points and Curves
bwiblue is on a distinguished road
I have a problem while creating points and curves within these points.
So far my script looks like that:
1 ic_undo_group_begin
2 ic_geo_new_family GEOM
3 ic_boco_set_part_color GEOM
4 ic_empty_tetin
5 for {set i 0} {$i<4} {set i [expr $i+1]} {
6 set x1_value [expr $i*2*0.04]
7 set x2_value [expr ($i*2+1)*0.04]
8 set point1_nr [expr $i*2]
9 set point2_nr [expr ($i*2)+1]
10 ic_point {} GEOM pkt$point1_nr $x1_value,0,0
11 ic_point {} GEOM pkt$point2_nr $x2_value,0,0
12 ic_delete_geometry curve names crv.$i 0
13 ic_curve point GEOM crv.$i {pkt$point1_nr pkt$point2_nr}
14 }
Now to my problem:
The script does not create the curve between the points (line 13). I have tried it without the variables for one curve. That worked perfectly. The source code looked like that:
ic_curve point GEOM crv.01 {pkt1 pk2}.
That is why i assume that the create curve command cannot handle the variables inside. Do you have any experience with that or do you know a workaround?
Thank you in advance for your help.
bwiblue is offline   Reply With Quote
Old   September 8, 2015, 04:06
FlorisvdBeek is on a distinguished road
Hi !
Okay so this answer may come a little over 2.5 years too late, but as your question still came on top of my google results:
I found that for scripting in ICEM, the quotes {$MYVAR} do not allow for variable substitution. You should use "$MYVAR" instead, i.e.:
ic_curve point GEOM crv.01 "pkt1 pk2"
Thanks for the 'for loop' though, that was what I was looking for in the first place
FlorisvdBeek is offline   Reply With Quote
Old   September 29, 2015, 10:27
Joakim
joxen is on a distinguished road
Originally Posted by FlorisvdBeek View Post
Hi !
Have some problem with scripting in ICEM aswell.
I want to control the vertex numbers and change them, or find the vertex number in a specific coordinate.
I have a vertex in point e.g (1,2,3) and want to extract the node number in this point. Do you know any code for that?
There is a function called : ic_hex_select_nodes
When using:
[CODE]
ic_hex_select_nodes 1 all m FLUID node_numbers
[\CODE]
All the node number associated to the FLUID part is returned, which is quite good. By changing "all" to inpoly and give the coordinates of a point it should be easy to select a node in a gives coordinate.
I've tried:
[CODE]
ic_hex_select_nodes 1 inpoly {369.13875 211.52306 -1.1669954e-10} m FLUID node_numbers
[\CODE]
And there is node in this coordinate so it should work but the error message "Error: Error reading polygon coords" is given.
Do you have any idea how to solve this or how to use
ic_hex_select_nodes with inpoly command instead of all.
Thank's for your help
joxen is offline   Reply With Quote
Old   September 30, 2015, 04:05
Antanas is on a distinguished road
Try this
ic_hex_select_nodes 1 inpoly 1 369.13875 211.52306 -1.1669954e-10 m FLUID node_numbers
Antanas is offline   Reply With Quote
Create geometry from mesh points in ICEM-CFD David Arthur Main CFD Forum 3 October 25, 2014 13:19
[ICEM] smooth curves from points mrenergy ANSYS Meshing & Geometry 3 March 9, 2013 18:46
[ICEM] Defining points and curves using MATLAB jeff.freeman ANSYS Meshing & Geometry 0 March 3, 2012 18:16
[ICEM] How to get points, curves, surfaces from unstructured mesh? TKE ANSYS Meshing & Geometry 0 October 21, 2011 11:01
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 10:03
