[ANSYS Meshing] ICEM structured grid: trying to maintain 1:1:1 blocks
Old   March 23, 2013, 15:14
Default ICEM structured grid: trying to maintain 1:1:1 blocks
Amy
BahaZero is on a distinguished road
Being new at ICEM, with some good help, I was able to get a decent looking hex mesh to extrude into my 3D model. However, I realized from my changes in mesh sizings (from far field to my focus region near the leading edge) the mesh looks good in 2D but not so much after being expanded to 3D. I ended up with some high aspect ratio elements (not including the BL) as I approached the leading edge. Please see the regions indicated by the left and centre arrow in my attachment.
Does anyone know if ICEM blocks can jump sizings from one block to the next? For example, have one block double the mesh size as the one adjacent to it yet maintain 2:1 node matching? (see zone indicated by the right arrow)
Thanks in advance.
BahaZero is offline   Reply With Quote
Old   March 25, 2013, 10:26
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
you can do that using refine block. the result will be hanging node which fluent has not problem dealing with it...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 28, 2013, 13:17
Amy
Thanks! That's exactly what I'm looking for!
how to generate a structured grid around a dimple using Pointwise? lachie Pointwise & Gridgen 8 October 28, 2010 22:37
Block Structured Grid aurel Siemens 0 October 21, 2005 10:19
ICEM HEXA Grid Manish Phoenics 0 March 12, 2005 06:07
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
Grid generator for structured grids Tore Myhrvold Main CFD Forum 5 January 21, 1999 09:09
