[ICEM] ICEM Structured Mesh Problem
Old   March 22, 2013, 07:09
Default ICEM Structured Mesh Problem
OMJT is on a distinguished road
Hi Everyone,
I am having a problem with my structured mesh. It meshes a relatively simple structure and consists of O-grids around the structure and then H-grid for the rest. At a low mesh density its quality is very high yet when I increase the mesh density some very strange things happen:
1) Originally the mesh started to distort massively and would overlap other bits of mesh and actually cover the solid part of the structure where the mesh should not be.
2) After this was solved by carefully breaking the structure down into separate curves and attaching the mesh carefully to this the mesh was exported to Fluent. Here I received an error that there was a node with no face. When I looked closely at the location the mesh had distorted there too! This point was well away from the structure and not somewhere where the mesh was doing anything special. It was on the boundary between an O-grid mesh and H-grid.
If anyone can help me with this it would be much appreciated! Why is increasing the mesh density having this strange effect?
Thanks!
Matt
OMJT is offline   Reply With Quote
Old   March 22, 2013, 08:06
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
that should not happen. some picture or files can help....
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 22, 2013, 08:09
AB
BrolY will become famous soon enough
Post pictures.
BrolY is offline   Reply With Quote
Old   March 22, 2013, 11:06
Thanks for the replies. I have photos which I will send when I am at that computer tomorrow.
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Saving Structured Multi-block mesh using ICEM CFD sachinspande ANSYS Meshing & Geometry 1 September 17, 2009 15:24
[ICEM] Problem with ICEM generated Mesh geothokar ANSYS Meshing & Geometry 3 May 11, 2009 14:26
