[ICEM] ICEM mesh problems for sinusoidal leading edge wing
Like Tree2Likes
Old   March 21, 2013, 20:00
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
Hi Stuart,
Icem replay scripting is a more difficult task than most people realise. I assume you are not creating the geom in ICEM, and are therefore using a geometry converter. The problem with this is that the converter must name every single point, curve and surface either by assigning names (pnt.01 etc), or by reading the names from the geometry file. Because most CAD file formats don't explicitly require a name for each geometry entity, the names of points curves and surfaces will be inconsistent when importing different geometry (especially if there is a large topology change). Try and see if your CAD package allows you to name all entities, otherwise you might have to resort to using ICEM for geometry creation as well.
Stu
Far likes this.
stuart23 is offline   Reply With Quote
wing with sharp trailing edge mesh through extrusion Hybrid Pointwise & Gridgen 18 February 9, 2017 11:31
[ICEM] Problems with export 2D mesh from ICEM to FLUENT newcomer ANSYS Meshing & Geometry 54 September 20, 2014 13:40
[ICEM] Meshing sinusoidal leading edge wing in ICEM ryerson_guy ANSYS Meshing & Geometry 39 April 10, 2013 03:57
Unstructured Mesh ICEM on a cube jerome_ ANSYS 0 May 30, 2012 06:34
[ICEM] 3d mesh around a wing using ICEM artemis64s ANSYS Meshing & Geometry 6 September 23, 2011 08:59
