March 18, 2013, 19:36 |
meshing in gambit
Rep Power: 13 |
hi every body
I want to mesh a cylindrical volume which is surrounding a wind turbine with three blades and one hub in gambit.I want to mesh this volume in a way which grids be smaller around the wind turbine. the wind turbine is located in a section of cylinder. picture of this geometry is attached. would you help me please??? |
March 19, 2013, 03:19 |
Maxime Perelli
Rep Power: 41 |
you may use size function
In memory of my friend Hervé: CFD engineer & freerider |
March 20, 2013, 18:30 |
Rep Power: 13 |
I had subtracted my wind turbine geometry of the cylindrical volume around it.so when I want to mesh it using cooper method in gambit,I got this error.
error:volume contains a void and thus cannot be meshed using cooper scheme. can any body help me plz? |
March 21, 2013, 02:07 |
Maxime Perelli
Rep Power: 41 |
you will never be able to mesh such a geometry on the fly with hexa or cooper. With tetra, you will.
For cooper or hexa you need to decompose your domain into smaller and hex-meshable subdomains
[ICEM] ICEM sizing function >>> Gambit and Ansys meshing | Far | ANSYS Meshing & Geometry | 0 | March 3, 2013 11:17 |
Gambit meshing error | jx | FLUENT | 11 | May 26, 2009 11:35 |
problem with gambit unsymmetrical meshing | meenakshi | FLUENT | 1 | March 28, 2008 13:46 |
meshing a fan using gambit | tony | FLUENT | 1 | February 15, 2008 01:28 |
Gambit: too long meshing time! | delsolman | FLUENT | 1 | January 29, 2008 20:06 |
