[ANSYS Meshing] How to start meshing this geometry? |
March 7, 2013, 03:30 |
Thomas Hoffmann
Rep Power: 14 |
Hi.
I'm not very familiar with Ansys meshing and I have to mesh the geometry attached. It is a nozzle with 3 inlets(when mirrored) in the top and an outlet in the bottom. Two fluids are mixed at the mixing zone in the middle of the nozzle. Can you help me with some guidelines and ideas for methods to use? Do I have to split the geometry or do other operations in designmodeler berfore I can mesh it? Thanks in advance Thomas |
March 7, 2013, 04:11 |
Javi
Rep Power: 16 |
I can say I´m a beginner. But looking for my geometry I saw this video on youtube: http://www.youtube.com/watch?v=KabKFrJK3fM Not is equal. But, maybe, it´s useful to see how to mesh the hydrocyclone because is similar to your geometry. |
March 14, 2013, 02:27 |
#3 | |
Rep Power: 14 |
2.Use fill option, to fill it with the Fluid. Then suppress the solid. Change the inside part from solid to fluid. 3.If you have a full model, Then use symmetry plane to split it into two. 4.Then in Ansys Meshing, if bodies are sweepable, I would choose Multizone/ Sweep mesh or else tetra(patch conforming-proximity and curvature). 5.Add inflation layers to the the nozzle and the other inlet. 6.In Fluent, choose the multiphase option, add the material and in bc's specify the values of mixture and phases. 7. If the flow is turbulent based on the Re, I would chose k omega (try k epsilon to see if it gives proper results and try with y+~30) turbulence model with wall functions and y+ value around 30 as there is no flow separation etc. I would add inflation layer after calculating y+ value and BL thickness (estimated from flow regimes in pipe) and then use these for initial thickness and no of layers values in inflation option. |
March 14, 2013, 10:27 |
Thomas Hoffmann
Rep Power: 14 |
thanks. I'm working with it.. Right now I have the problem that I can't mesh it when I have the face seen on picture 2 as symmetry. The error is 'an inter-process communication error occurred while communicating with the MESHER module.'
If I remove the named selection 'symmetry' there is no problem?? |
March 16, 2013, 00:23 |
#5 | |
Rep Power: 14 |
http://www.eureka.im/5199.html http://www.cfd-online.com/Forums/ans...eneration.html |
[ICEM] Meshing an irregular geometry | Fabio Tabacow | ANSYS Meshing & Geometry | 6 | May 7, 2014 17:03 |
[ICEM] Geometry Meshing | protea | ANSYS Meshing & Geometry | 2 | November 22, 2011 13:15 |
[ANSYS Meshing] Using more than one meshing method on a single 2D geometry | robbierich90 | ANSYS Meshing & Geometry | 0 | October 30, 2011 14:12 |
[ANSYS Meshing] Help - Meshing 2 Surfaces On A 2D Geometry | Ali_M | ANSYS Meshing & Geometry | 4 | March 29, 2011 04:01 |
Problematic geometry in Ansys Meshing | ATOTA | ANSYS Meshing & Geometry | 1 | October 9, 2010 12:51 |
