[ICEM] Meshing sinusoidal leading edge wing in ICEM
Like Tree3Likes
Old   April 8, 2013, 05:45
ryerson_guy is on a distinguished road
Last pic is attached
ryerson_guy is offline   Reply With Quote
Old   April 8, 2013, 05:46
Showpony I have tried that method before but didn't work out for me.
Old   April 8, 2013, 06:10
Stuart
ShowponyStuart is on a distinguished road
What problems did you have with it last time? I might have had the same issues. I spent ages getting it to work properly (though it was my first time using ICEM lol)
I started of doing it the same way you did but found it too tedious and not worth it as I could get the same (or better) results doing it without splitting the block in the spanwise direction.
I will have another look in a moment, but I have a feeling that FAR will be much more help to you than I will be. But I will Try
ShowponyStuart is offline   Reply With Quote
Old   April 8, 2013, 06:29
Stuart
One thing I have notices is that you do not have many elements in the spanwise direction. You are barely going to capture the geometry with 8 elements across let alone get any decent resolution of your flow. It will up your element count A LOT but really is probably necessary. If you want to reduce node count you might have to consider a hybrid mesh.
I know in my simulations there is definite 3D flow effects, so if you want to capture them you are definitely going to have to increase the element count in the spanwise direction.
I increased the node count to 12 across each block in the spanwise direction and then projected to edges as mention earlier and I had no problems with volume errors.
https://www.dropbox.com/s/00ft3ejsjz...%20%282%29.zip
Also, if you separate the walls you called symmetry into symmetry1 and symmetry2, you can turn of one of the walls and get a much clearer idea of what is happening with the mesh (because you dont get all that extra interference).
Make sure you renumber the nodes and reduce the bandwidth too if you are struggling to deal with teh extra amount of nodes. Should help a bit.
Old   April 8, 2013, 16:11
Sorry the files that I uploaded and the one the pics have a mismatch. The pic has 40 elements along the span, where as the files have less. I still get the same error whenever I try to improve.
Old   April 9, 2013, 00:44
Does the way your geometry was drawn and imported to ICEM matters? The initial one and the ones i uploaded were drawn and imported a different way.
Old   April 9, 2013, 03:38
Stuart
Not sure what you are talking about man. Did you even look at either of the files I sent you? 40 elements across is not enough. I ended up doing 12 element on each of the blocks. ie. 12x8=96nodes on the spanwise direction.
I got that rar file you uploaded working fine by doing what I said. the "tubercle_0.5cwave"
The "tubercle_0.2cwave" hasnt been blocked or anything so Im not sure what was going on there.
All I did was increase the amount of spanwise nodes significantly and change the premesh from "project to face" to "project to edge". Literally all I did. Ran the check and there were no errors.
Old   April 9, 2013, 06:56
So you just increased the elements in my files as well as projecting edges thats it?
Old   April 9, 2013, 07:15
You didnt change my blocking method?
Old   April 9, 2013, 07:16
Stuart
Didnt change blocking, just increased the elements in my files as well as projecting edges and it seemed to work nicely for me.
Old   April 9, 2013, 07:20
Would you mind uploading the file please? I am doing the same thing as you and yet having errors again
Stuart
That said, I still wouldnt bother splitting your blocks like that. It is pretty much a waste of time. can get the same results without splitting it in the spanwise direction
Old   April 9, 2013, 07:21
Stuart
I already did it earlier
but here it is again
EDIT: You mean the same thing with the increasing spanwise nodes and projecting to edge?
Old   April 9, 2013, 07:24
Yes increasing spanwise nodes and projecting edges. The link to the file doesnt work.
Old   April 9, 2013, 08:04
Stuart
See if that works now
Old   April 9, 2013, 12:55
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
problem in geometry
Far is offline   Reply With Quote
Thanks for the upload, but i still see some negative determinants elements although they are very small. Are you using Fluent to run your cases?
Old   April 9, 2013, 16:11
Far is there a way I can look for geometry errors in ICEM?
Old   April 10, 2013, 01:07
Stuart
I was running the check in ICEM. I found that if I have no problems in icem then I will have no problems in CFX.
Old   April 10, 2013, 03:57
Far
Sijal
Why it is not projecting to geometry?
ICEM Hexa meshing tutorial - Wing with sharp trailing edge Far ANSYS 1 May 18, 2012 15:19
[ANSYS Meshing] Hybrid meshing ICEM djoul ANSYS Meshing & Geometry 2 January 17, 2012 19:18
[snappyHexMesh] Meshing 3D wing (hydrofoil) fails klausb OpenFOAM Meshing & Mesh Conversion 0 December 28, 2011 15:26
Meshing for 3D wing with tubercle on the leading edge in GAMBIT nvtrieu FLUENT 0 August 14, 2010 11:13
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge TWaung CFX 2 February 16, 2010 09:11
