[Other] Cutcell meshing skewness
Old   February 27, 2013, 18:18
Default Cutcell meshing skewness
Ronato Said
RSaid is on a distinguished road
I have decided to use the cutcell method to mesh the volume of fluid around the hull but this method is giving me some trouble with the skewness of some cells ( less than100 cells are highly skewed) which is larger than 0.98. I have tried different sizing functions but this did not help to lower it.
> Do you have any ideas on my current problem which may help me ?
is skewness in cutcell a big problem ? (i.e. will fluent have problems in convergence ?)
thanks!
RSaid is offline   Reply With Quote
Old   December 16, 2014, 13:09
Zach Smith
zachsmith is on a distinguished road
Bump. I am having the same issue with this. I have had this issue with high skewness cells on the edge of cylinders with multiple meshes now. So I believe it is most likely something that I am not doing correctly. Any help would be appreciated.
Thanks
zachsmith is offline   Reply With Quote
[ANSYS Meshing] Ansys meshing result very high skewness m5edr ANSYS Meshing & Geometry 18 February 3, 2020 12:35
[ICEM] Meshing problem - skewness norger ANSYS Meshing & Geometry 1 July 24, 2012 04:44
[ANSYS Meshing] Periodic issues in cutcell meshing jsm ANSYS Meshing & Geometry 7 March 8, 2012 22:00
[GAMBIT] fac meshing problem, not skewness bugra ANSYS Meshing & Geometry 0 September 3, 2010 08:40
Severe nonorthogonality and severe skewness problem qtian OpenFOAM Running, Solving & CFD 2 January 22, 2008 19:47
