[ICEM] Effect of globle mesh size and mesh independency
Like Tree1Likes
Old   September 29, 2019, 08:36
Ugee
Ugee is on a distinguished road
thanks for your reply
Actually I am working on prototype geometry .Initial height of the mesh I calculated using Y+ formula. In mesh part set up of ICEM i have mentioned maximum height once 11 mm and 10 mm and the total number of elements for 10 mm and 11 mm were differ by nearly 1 millions. so can you suggest me for selecting maximum mesh size .
and also I have taken prism layer across the wall. its cut section view showed 3 default prism layer near to the wall and after then rapid expansion of the mesh . Y + value from the cfx post is in the range of 4 to 4031 . I increased the number of layer to 10 with default prism height ratio 1.2 ,the number of element below 0.3 quality is too many (nearly 15000)
If we take prism layer with tetra mesh how to improve the mesh quality
Answer will be appropriated
Ugee is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
