[ICEM] airflow in an annular space between outer and inner pipe |
February 20, 2013, 06:05 |
ahmad
Rep Power: 14 |
I need your expertise for my case, I have airflow in an annular space between outer and inner pipe with sudden expansion (inner pipe solid and one part heated and second part unheated. I have problem with interior part for meshing thus as I make blocking for each part and meshing then the interior part remain without mesh. Please can you solve this problem and export the mesh to fluent because some time the fluent give me error such as non-positive volume. Please find the attach file with ICEM
I will appreciate your help and looking forward receiving your communications Thanking you |
February 20, 2013, 07:23 |
#2 | |
htokan
Rep Power: 17 |
February 20, 2013, 13:05 |
ahmad
Rep Power: 14 |
Dear Sir Far,
Firstly, a lot of thanks for you, My dear brother earlier I reached this step from the project but still same problem interior without mesh and also when I import mesh in fluent there is error (non-positive volume) Please I need from you meshing the interior and import the fluent without error (non-positive volume). Finally I need you to write me all the steps you will do it. Please find the attach file involve two picture for my case I will appreciate your help and looking forward receiving your communications Thanking you Yours sincerely |
February 20, 2013, 13:10 |
#5 | |
htokan
Rep Power: 17 |
February 20, 2013, 13:24 |
ahmad
Rep Power: 14 |
my Dear brother, still interior without mesh. Please see the attach file
Thanking you |
February 20, 2013, 13:32 |
#9 |
Hey
You really need mesh in interior (and please don't use the word which is already reserved for some other purpose, it makes confusion ) If you give it boundary (wall) your flow will not flow from this boundary, or if you give it as inlet or outlet it will be mathematically wrong. Trick is " associate face to surface" I also want to know do you need inside the solid part? Otherwise mesh is perfectly fine. |
February 20, 2013, 13:38 |
#10 | |
ahmad
Rep Power: 14 |
February 20, 2013, 13:40 |
#11 | |
ahmad
Rep Power: 14 |
February 20, 2013, 13:46 |
#12 |
February 20, 2013, 13:50 |
#13 | |
ahmad
Rep Power: 14 |
Thanking you |
February 20, 2013, 14:01 |
#14 |
ahmad
Rep Power: 14 |
February 20, 2013, 14:13 |
#15 | |
htokan
Rep Power: 17 |
I got your point Please see the picture |
February 20, 2013, 14:45 |
#17 |
February 20, 2013, 14:47 |
#18 |
ahmad
Rep Power: 14 |
February 20, 2013, 15:14 |
#19 |
ahmad
Rep Power: 14 |
Dear Diamondx,
I import the mesh file in fluent and apply boundary condtion but as 3 iteration i got divergance as shown in attach picture |
February 20, 2013, 16:23 |
#20 |
htokan
Rep Power: 17 |
I said only Simon he has ability to solve this problem. Where is simon ??we waiting solving....
