[ICEM] Adding parts to Plot3D Mesh
Old   February 18, 2013, 15:34
Default Adding parts to Plot3D Mesh
Colin Fiola
CDollarsign is on a distinguished road
I was provided a very good quality mesh in p3d format. It looks like I cannot add any parts to create boundary conditions which associate to the mesh. Is there anyway to do this? It will save me a lot of time by not having to re-create the mesh.
Thanks in advance!
CDollarsign is offline   Reply With Quote
Old   February 18, 2013, 15:47
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
have you tried to import the mesh successfully in icem ???
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   February 18, 2013, 15:49
Colin Fiola
The mesh comes in fine, the only problem is that it seems to be two parts. So I would like to create some parts and export it into fluent. I have made some parts but when I export they don't make it into fluent. I think it is because they are not related to the mesh at all...
Old   February 18, 2013, 15:52
diamondx's Avatar
Ghazlani M. Ali
ok, remember boundary condition means you have to select only 2d shells...
starting from here, in the outline tree, where you have part, right click, select new part, there you will be prompted to select the elements you want, type INLET in the name in then select the shell that you want to represent the inlet with...
Regards,
Ali
Old   February 18, 2013, 15:54
diamondx's Avatar
Ghazlani M. Ali
you should get something like this to filter your selection, i always use the limit by curve or angle :
Regards,
Ali
Old   February 18, 2013, 16:23
Colin Fiola
That seems to work! I get some weird stuff in fluent though, it wants to convert some of the zones to 'shadow' zones. Any idea what that is about?
Old   February 18, 2013, 16:25
diamondx's Avatar
Ghazlani M. Ali
sorry , i don't...
Regards,
Ali
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
