February 5, 2013, 08:53 |
Union of blocks in ICEM
Talles Caio
Rep Power: 14 |
I had to redo a portion of the blocks of my geometry, but now need to unite the blocks, because when extrude face is like having two blocks, is there any way to do this in ICEM?
February 5, 2013, 09:28 |
Ghazlani M. Ali
Rep Power: 29 |
in the blocking tab -> edit block -> merge blocks. Sometimes that features doesn't work as expected... you can select the block you want to merge or hit automatic, it will do it for you
February 5, 2013, 09:53 |
Talles Caio
Rep Power: 14 |
I understand, but I want to connect two blocks between them where there is an empty space, how exactly do I do this?
February 5, 2013, 10:16 |
Ghazlani M. Ali
Rep Power: 29 |
in the create block tab, instead of clicking initiliaze block, select create block from face or vertices. it will add a block there. my guess you can merge them later. altough i'm curious if merging vertices will do the same too ?! can you try first with merge vertices ? the second one always work anyway
February 5, 2013, 11:34 |
Talles Caio
Rep Power: 14 |
thanks man, merge vertices working!!!!!
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 06:59 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 17:14 |
[ICEM] Deleting VORFN blocks in ICEM CFD | Sai Swaroop | ANSYS Meshing & Geometry | 5 | October 18, 2011 11:26 |
Merging the blocks in ICEM | saisanthoshm88 | ANSYS Meshing & Geometry | 1 | December 27, 2010 11:14 |
A problem with blocks in Icem | Janne | CFX | 2 | February 21, 2008 09:37 |
