[Other] Problem with negative volume in CFX
Old   February 4, 2013, 11:00
Default Problem with negative volume in CFX
Talles Caio
TallesC is on a distinguished road
Guys, I'm trying to run a case in cfx, but the next problem was reported:
* ERROR # 002100012 has occurred in subroutine cVolSec. |
* | Message: |
* | A negative ELEMENT volume Has Been detected. This is a fatal |
* | Error and execution will be terminated. The location of the first |
* | Reported negative volume is below. |
* | Volume:-0.1504E-09 |
how can I solve this problem??
TallesC is offline   Reply With Quote
Old   February 4, 2013, 11:22
Christoph
energy382 is on a distinguished road
* | Message: |
which software did you use? cfx mesh? icem?
you have some negative vol. elements and have to fix them
energy382 is offline   Reply With Quote
Old   February 4, 2013, 12:10
Talles Caio
I use ICEM, how exactly do I do this??
Old   February 4, 2013, 12:44
Christoph
check your det 2x2 or det 3x3 to find the negative cells. i don't know, if you use tets or hexa. if you use a blocking approach, then check your associations (rmb on edge/show association) or use a scan plane.
Negative Volume during Mesh Motion Analysis giov_ingr FLUENT 2 December 13, 2013 07:09
Negative cell volume problem in-cylinder ziani.lotfi FLUENT 0 April 11, 2012 08:54
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
