[GAMBIT] successive ratio on meshing edge
Old   February 2, 2013, 10:50
Default successive ratio on meshing edge
domenicoBUFF is on a distinguished road
Hi! First meshes with Gambit. Please, how to mesh an edge with n points at increasing distance each other, and starting with the first cell as fixed at for example at 1 m (total edge of 1 km). The control I need is on the first of e.g. 1 m, then I'd apply an incremental ratio, e.g. n = 2 gives 1 m + something (e.g. 0.2 m), etc... Which parameters aren't to be fixed? Is first length to be used in Gambit, and how? Very many thanks!
domenicoBUFF is offline   Reply With Quote
Old   February 4, 2013, 03:00
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I didn t get your point (maybe a sketch would help)
anyway: http://aerojet.engr.ucdavis.edu/gamb...mesh_edge_mesh
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 08:42
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
