February 1, 2013, 07:19 |
bad quality
tmeysam92
Rep Power: 15 |
HI all,
i meshed a nozzle in ICEM cfd , but the quality is not good. what should i do? thanks in advance. |
February 1, 2013, 09:22 |
AB
Rep Power: 22 |
Add at least one or two splits to your blocking.
Maybe adjust the edges of the inner O-Grid to optimize the quality. |
February 1, 2013, 09:32 |
Slightly more complicated CD nozzle meshing is discussed in this thread.
http://www.cfd-online.com/Forums/ans...tml#post397666 |
February 1, 2013, 11:26 |
#5 | |
tmeysam92
Rep Power: 15 |
the problem is that my geometry is made from 4 curves. i mean i first import curve points to Catia then i use revolve tool to make the nozzle. could you please take a look at my geometry and tell me what should i do ??? thank you very much. regards, meysam |
February 1, 2013, 11:47 |
#6 | |
I just made few splits and snaped vertices and every thing is fine. By the way, are you going to make the far field? |
February 1, 2013, 12:08 |
#7 | |
tmeysam92
Rep Power: 15 |
yes. at first step i want to mesh just the nozzle. then i will create a cylinder around the nozzle,and will mesh the volume between the nozzle and cylinder. |
[ICEM] mesh at the corner: bad quality | hz283 | ANSYS Meshing & Geometry | 1 | December 18, 2012 12:45 |
[ICEM] The pre-mesh quality is very good but the mesh quality is bad | lnk | ANSYS Meshing & Geometry | 5 | July 30, 2012 15:11 |
how to deal with bad quality cells? | phsieh2005 | OpenFOAM | 3 | July 20, 2011 10:35 |
[ICEM] Hex refinement negative quality afterwards | Anorky | ANSYS Meshing & Geometry | 8 | March 22, 2010 04:25 |
Tgrid and export bad quality cell | mohr76 | FLUENT | 0 | February 15, 2007 10:03 |
