[ANSYS Meshing] Blade tip blocking
Like Tree6Likes
Old   March 6, 2013, 06:49
Francisco
Bollonga is on a distinguished road
I've been moving vertices and changing nodes number, negative volumes change in number and distribution (see pics) but they are always there.
I've been checking http://www.youtube.com/watch?v=tYrbScUH9RE for some blocking ideas but every blocking strategy I try to imitate gives negatives volumes for me.
Is there any base problem?
Isn't it a common mistake in Icem practice? Cause I'm facing it too often!
Any suggestion? Thanks!
Bollonga is offline   Reply With Quote
Old   March 6, 2013, 06:55
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
please attach .tin
Far is offline   Reply With Quote
Old   March 6, 2013, 07:06
Francisco
Here you are
Old   March 6, 2013, 08:37
Far
Sijal
blocking 1 is perfect. No problem of negative volume
Old   March 6, 2013, 08:46
Francisco
I've converted one of the meshes to unstructured and then exported it to fluent and it doesn't detect any negative volumes! I had tried that before with no success but now it works...
How does the pre-mesh to unstructured step work?
Apparently Negative Volume indicator doesn't mean too much...
Which quality parameters should I pay attention to? Quality, angle, volume change?
Thanks!
Old   March 6, 2013, 09:03
Far
Sijal
Qaulity, min angle and volume change. Also dihedral angle (should be less than 165)
Old   March 7, 2013, 06:01
Francisco
Which values would be appropiate for that? I've read min quality > 0.2, min angle >18 and max volume change??
Old   March 7, 2013, 06:04
Far
Sijal
Min quality > 0.3, min angle > 18 amd volume change <20
Old   March 7, 2013, 06:08
AB
BrolY will become famous soon enough
Thanks!
You won't see negative volume unless you do a check mesh on the unstructured mesh. But if you look at the quality, you would find a lot of elements with a quality around 0. Those elements are your negative volume elements
About the values of quality, Far is right, but quality, > 0.2 is good too.
BrolY is offline   Reply With Quote
Old   March 7, 2013, 06:37
Francisco
For the same mesh I get negative volumes at the pre-mesh and quality over 0.6 at the unstructured mesh. I don't understand why. (attached files)
Then in fluent it doesn't show any negative volumes.
However, for this mesh, my fluent case diverges from the beginning. I'm using 33.87 m/s, k-ep standard with TI=1% and TLS=1e-4m at the inlet. Adaptive time-step starting at 1e-8. I've tried reducing under-relax factors one order of magnitude but it doesn't avoid divergence.
Old   March 7, 2013, 06:42
AB
No negative volume in this project, the pre-mesh quality > 0.8.
Old   March 7, 2013, 06:51
Francisco
But if I select Volume in the quality menu, select histogram form -1 to 0 you can see there are negative volumes. In the image there's the histogram from 1e-15 to 0 showing many elements, even if quality histogram is >0.6...
Old   March 7, 2013, 06:53
Far
Sijal
check " only visible index range"
Old   March 7, 2013, 06:55
Francisco
Nothing changes
Old   March 7, 2013, 07:30
Francisco
I've discovered that just changing the min distance of the edge near the wall from 1e-5 to 5e-5 it improves quality a lot, from having near zero quality elements to a minimum quality of 0.6. It's pretty sensitive to node distribution!
Old   March 7, 2013, 10:11
Default naca wing volume change
  #76
Francisco
Okay, so negative volumes is solved so far. Now I want to make some test with the mesh but it diverges no matter what I do.
I've tried ke-epsilon standard (enhanced wall treatment) and k-om SST aswell for steady and transient case. Mesh quality is good, volume change is not that good I guess (see histogram and element distribution in picture 2).
Could it be the problem for not reaching convergence?
Could I reach convergence with a coarser mesh?
Thanks!
Old   March 7, 2013, 11:16
Francisco
Thanks!
I thought an appropiarte volume change was 20% so I understood that higher than 1.2 was not good. But as I've read in the user guide, less than 20 means 20 times the maximum neighbour volume. So my volume change dsitribution is pretty good! So I don't know what can be wrong
Old   March 7, 2013, 11:20
Far
Sijal
Just few thoughts:
1. Open up mesh in far field. In other words do not carry forward mesh sizing and growth ratio in farfield. Instead make spacing uniform and use match edges.
2. check domain extents
Old   March 7, 2013, 14:13
Francisco
I haven't understood it completely. You mean I shouldn't keep edges parallel until far field but to open them?
And use uniform spacing instead of hyperbolic or geometric or whichever?
Which edges should I matche to which ones?
Thanks!
Old   March 8, 2013, 05:26
Far
Sijal
Download file from first post in following thread and look at the meshing in farfield.
http://www.cfd-online.com/Forums/ans...take-mesh.html
blade tip, hexa mesh, sharp edge, wind turbine
Meshing very thin blade tip Jenny CFX 7 June 27, 2014 09:26
Blade tip with tetra/prism method vinc ANSYS Meshing & Geometry 0 May 17, 2011 16:22
[ICEM] Blocking of impeller single blade sector (MRF) delaneyluke ANSYS Meshing & Geometry 1 May 6, 2011 10:28
[ICEM] Blocking strategy for 1mm tip clearance mr_stoked ANSYS Meshing & Geometry 2 September 21, 2010 16:00
[ICEM] Turbine blade with filleting and tip clearance Pursuor ANSYS Meshing & Geometry 4 July 7, 2010 14:56
