February 25, 2013, 09:05 |
#41 |
AB
Rep Power: 22 |
Your blocking stratégy is wrong ... way too complex.
See attached what I would have done. Just think that O-Grid is good only with circle shape ... that's all, it's not a good idea with rectangular shape. |
February 25, 2013, 09:15 |
#42 |
Francisco
Rep Power: 15 |
Thanks BrolY, the strange thing is when I reduced the bunchings in the x directions I had no negative volumes. I don't see why that happened.
In the blade problem, is block orientation a possible cause for negative volumes? I attach a picture of blocks colored by orientation. |
February 25, 2013, 09:21 |
#43 |
AB
Rep Power: 22 |
In fact, it makes sense ... the blocks were highly distorted. If you add more or less nodes, ICEM would sometimes manage to handle this distortion, sometimes not. It would depend on the number of nodes.
As I said before, I can't help you without .tin and .blk files, but try to move vertices in order to correct block distortion. By the way, you said you can't share the .tin file because someone else created the geometry. But you can share the .blk file, it's yours ! Maybe we could help you a little bit more with it ... |
February 25, 2013, 11:55 |
Blocking files
#44 | |
Francisco
Rep Power: 15 |
Thanks a lot! |
February 26, 2013, 03:50 |
#45 |
AB
Rep Power: 22 |
I had a quick look at your blocking file.
There are a lot of troubles : splits which are not propagated as they should (that is not an issue, unless you are really confotable with blocking), vertices which are not aligned correctly (so blocs are distorted) etc ... Far could help you more than me here, but I think you should redo from the beginning your blocking and watch some videos on youtube ... |
February 26, 2013, 04:41 |
#46 | |||
Francisco
Rep Power: 15 |
Thanks BrolY,
http://www.cfd-online.com/Forums/ans...ca0009-3d.html I was trying to be systematic with the blocking but I had to move many vertex to get blocks simpler and closer to the blade surface. But yes, I'm thinking on redoing all the blocking from the beginning. I'm also also checking the forum for similar cases and making trials with a simpler geometry too. Any useful videos? Besides turboengineer channel http://www.youtube.com/user/turboengineern |
February 26, 2013, 05:13 |
#47 |
AB
Rep Power: 22 |
Vertices need to be as much as possible aligned. Because a block is defined by 4 vertices, so if they are not well aligned, your block would be distorted.
When the block is rectangular, you have a perfect mesh with a determinant of 1 and a min angle of 90°. But the more you move vertices, the lower the quality is reduced. That's why it's recommanded to have a determinant > 0.2 and a min angle > 18° to have bad elements. |
February 26, 2013, 05:49 |
#48 | |
Francisco
Rep Power: 15 |
March 4, 2013, 05:51 |
Negative volumes in a simpler case
#50 |
Francisco
Rep Power: 15 |
Hello everybody,
I'm making some tests to understand how the negative volumes appear so I'm using a simpler geometry of a NACA cylinder without twist nor chord length change along the height as the blade is. I'm trying to use a very simple blocking, including an o-grid, with very small element height near the surface in order to avoid wrong y+ values later on. Even so, negative volumes still appear all over the surface. How can I avoid that? Should I make the o-grid length bigger? Should I use shorter blocks along the cylinder height? Can it be due to lack of orthogonality next to surface elements? Could anybody take a look at my geometry and blocking and give me any advice? Thanks a lot, guys. |
March 4, 2013, 08:10 |
#52 |
Francisco
Rep Power: 15 |
So what could be a more appropiate blocking?
I've tried with a more adapted to rounded shapes one, I've moved some vertex but same results. (see attached file) |
March 5, 2013, 03:29 |
#55 |
Francisco
Rep Power: 15 |
Wow! Thanks a lot Far!
I was watching your video: http://www.youtube.com/watch?v=mgjRT4WY_iA Some questions about your blocking: Would the inner o-grid be necessary if the cylinder went from side to side and there were no need to do the internal section mesh? Putting and edge along the trailing edge is not recommended? Is an o-grid necessary in the outside of the wing or should I avoid it? Can I use this approach for the twisting blade? Should I divide the blocks along the blade height not to get very twisted ones? Now I have to do that with the rounded tip so I have to "merge" your methodology for the Naca wing and Ralen's for the rounded tip. And eventally apply all that to the blade... Another mesh I gotta do is a T-intersection of NACA wings like this one. I'll upload here the geometry. Thanks for the help. I really appreciate it! |
March 5, 2013, 07:33 |
Negative volumes again
#56 |
Francisco
Rep Power: 15 |
I've done the blocking again, except that inside the wing, it's not complicated but in the end I get many negative volumes in the upwind area! Why?? I've run the fix check/fix blocks tool and fix inverted blocks with no luck.
I upload pictures and files. |
March 5, 2013, 07:36 |
#57 |
collapse trailing edge. Trailing edge is very sharp and this blocking strategy wont work. Try the one I posted earlier.
Edit : Min quality is now 0.06 after adjusting the vertices and increasing no of nodes from 15 to 40. Last edited by Far; March 5, 2013 at 07:56. Reason: update |
March 5, 2013, 09:28 |
#58 |
Francisco
Rep Power: 15 |
March 5, 2013, 10:33 |
#60 |
Francisco
Rep Power: 15 |
I've tried the previous blocking with a collpased trailing edge but I still get negative volumes (see picture 2) . I attach the files.
I'm starting to have nightmares with negative volumes |
blade tip, hexa mesh, sharp edge, wind turbine |
Meshing very thin blade tip | Jenny | CFX | 7 | June 27, 2014 08:26 |
Blade tip with tetra/prism method | vinc | ANSYS Meshing & Geometry | 0 | May 17, 2011 15:22 |
[ICEM] Blocking of impeller single blade sector (MRF) | delaneyluke | ANSYS Meshing & Geometry | 1 | May 6, 2011 09:28 |
[ICEM] Blocking strategy for 1mm tip clearance | mr_stoked | ANSYS Meshing & Geometry | 2 | September 21, 2010 15:00 |
[ICEM] Turbine blade with filleting and tip clearance | Pursuor | ANSYS Meshing & Geometry | 4 | July 7, 2010 13:56 |
