January 28, 2013, 19:13 |
#21 |
select solid block (inside plate) and slect optin around and click apply and your are done. If you have deleted the block inside plate then turn on VORF and send inner block to solid by creating new part.
January 29, 2013, 11:08 |
#22 |
Francisco
Rep Power: 15 |
Fine, it was just I was getting O-grid blocks all around the external contour. Thanks.
flat plate, hexa mesh, icem, negative volumes |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
