[ICEM] Export Geometry from the ICEM
Old   January 21, 2013, 10:54
Question Export Geometry from the ICEM
Astio Lamar
asal is on a distinguished road
Hello everyone.
I have import a geometry from a cad file to ICEM to made some modification.
then I export the geometry as .IGS and or .STL
but there is something strange here!! when I want t import again this exported geometry, then the only surfaces which I made in ICEN (the surfaces which are created in the modify process) will open and the other surfaces which are originally created vanished! So I have just the surfaces and curves which I built in ICEM and not builted by CAD file.
hopefully I can explain what is going on.
Is any body has any idea about the case?
asal is offline   Reply With Quote
Old   January 21, 2013, 11:49
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Export in step and parasolid. And import both and see what you get.
Far is offline   Reply With Quote
Old   January 21, 2013, 16:46
Astio Lamar
Hello and thanks for your reply
In the ICEM, you cannot export to step file! how can I do that?
for exporting in Parasolid format I got this error:
ICEM CFD - Parasolid Writer 12.0.1 (Build 9.4.10.16)
Parasolid Kernel Version 19.1 (Build 307)
Copyright (C) 2009 Ansys Inc./ICEM CFD Engineering
Checking for License...Failed.
child process exited abnormally
Done.
Old   February 3, 2013, 07:54
Astio Lamar
Any Idea?!
Old   February 3, 2013, 09:01
Far
Sijal
it look likes a license issue.
ICEM export mesh Youen ANSYS Meshing & Geometry 34 April 23, 2017 13:15
[ICEM] ICEM changes geometry mariusk87 ANSYS Meshing & Geometry 14 June 20, 2012 09:52
[ICEM] Meshing adjacent wall geometry and simple ICEM questions everdimension ANSYS Meshing & Geometry 25 June 20, 2012 05:25
[ICEM] Best way to import geometry ICEM Cottbus ANSYS Meshing & Geometry 4 June 12, 2012 10:42
Exporting geometry from Solidworks to ICEM! Usman CFX 1 November 27, 2007 17:20
