[ICEM] Meshing strategy/values
Old   January 16, 2013, 12:55
Default Meshing strategy/values
powpow is on a distinguished road
I'm a newbie with meshing. But with the help of some tutorials and this forum, I was able to create my first mesh.
Since it is my first mesh, I don't know at all which values should be entered
To get an impression of the size, the dimensions of the test chamber are:
Length: 14 458 mm
Diameter: 3032 mm
So I tried it this way:
- Register Mesh - Surface Mesh Setup - Surfaces: I selected all surfaces, entered Maximum size: 150, Height: 150, Min size limit: 20 and all others: 0 - Apply.
- Register Mesh - Compute Mesh - Volume Mesh - Compute. Volume Mesh is Tetra/Mixed and Mesh Method is Robust (Octree)
- Check Mesh and ignoring multiple edges and single edges since they shouldn't be a problem. Delete unconnected vertices.
- Then, I wanted to add 10 layers of prism:
- Register Mesh - Compute Mesh - Prism Mesh.
- There I selected the parts for the prism layers, entered there num layers =10 and clicked "ok".
- Then I clicked surface mesh up, chose the surfaces of the tube and the small nozzle, changed Maximum size: 50, Height: 5, Min size limit: 10, Height Ratio: 1.5 and applied.
- Register Mesh - Compute Mesh - Volume Mesh. I enabled create prism layers and computed.
- Check Mesh and again ignoring multiple edges and single edges.
The result is shown in image001.
Unfortunately, some errors occured while doing the simulation with CFX-Solver Manager (see image002).
I hope someone can tell me, if the problem was the mesh or perhaps adjustments in CFX-Pre..
powpow is offline   Reply With Quote
Old   January 16, 2013, 12:57
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
It is better to post this problem in the CFX section you get lot of helps there
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 16, 2013, 13:40
Thank you for your advice, I will try it there
Old   January 16, 2013, 16:41
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Length: 14 458 mm
Diameter: 3032 mm
Mesh is one of the possible problem.
Far is offline   Reply With Quote
Old   January 16, 2013, 16:58
Thanks! Do you know how I could create a better mesh
Old   January 16, 2013, 17:00
Far
Sijal
Through ICEM Hexa.
Old   January 16, 2013, 17:13
And which Parameters should I try?
Old   January 17, 2013, 04:37
AB
BrolY will become famous soon enough
Tetra+Prism can create good meshes too which can give good results ...
Hexa meshes can provide, sometimes, better results, but if your computation parameters are wrong, it would give you the same bad results as with tetra+prism meshes.
So I think, you should first ask your question to the CFX forum, and if all your computation paramters are good, come back here with pictures which show the problem on the mesh ..
BrolY is offline   Reply With Quote
Old   January 17, 2013, 14:15
Thank you for all of your advice
I created my first mesh which could be solved!
My procedure was the same as described in the ICEM CFD Tutorial "Tetra/Prism Mesh Generation for a Helicopter" except the following changes:
- To generate the Octree Mesh I entered 0 (=autosizing) for "Max element" at the Global Element Seed Size in the Global Mesh Size Setup.
- My Part Mesh Setup is shown in the picture below.
- I created no density box!
Do you have any hints what can be done better?
E.g. what can I do if I want a finer mesh?
Old   January 17, 2013, 14:34
Far
Sijal
try patch dependent mesh....
Old   January 17, 2013, 16:28
at which step?
Old   January 17, 2013, 16:53
Far
Sijal
on surfaces and fill volume with denauly. Your other setting e.g. int wall seems correct.
Old   January 18, 2013, 04:41
When looking at CFD-Post at the moment, I found another problem :
I built my CAD-Modell in Catia in mm. The scale at CFD-Post now says it's in m?!
What do I have to change?
Old   January 18, 2013, 12:39
Far
Sijal
scale in either ICEM or CFX-Pre/Fluent....
But if the length dimension are still the same, I mean if you have generated 1000 mm length and CFD-post is showing 1 m instead then no need to worry.... That can also be fixed in CFD-post...
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 06:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 12:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 12:08
