[ICEM] unstructured 2d airfoil mesh
Old   March 7, 2022, 18:26
jose daniel
hoyos98 is on a distinguished road
I suggest you visit https://aeroptimal.com/mesh (you must create an account to use this module), where you can create a full structured airfoil mesh - https://youtu.be/4Opu0zk7gFk . You can export .su2 .msh .foam .vtk
hoyos98 is offline   Reply With Quote
Old   June 7, 2023, 04:48
baditlm is on a distinguished road
Originally Posted by Mazur View Post
OK so now I'm understanding the idea of build topology.
Now I'm using those curves that create when I'm splitting the FLUID surface. And I get an inflation layer. But still I'm not able to split that curve into two curves. When I do it with geometric options I don't get mesh at all. And the inflation layer doesn't look good in the tail of the airfoil. And also the tetra elements sorrounding the tail of airfoil are in my opinion way to big. I post a picture that shows how does it look like. Can I make it somehow better?
Also about controling the tetra growth from the airfoil (over the inflation layer). I did it by making a rectangular shape and by splitting the FLUID surface into two parts, and then by setting parameters to the surface (max elem size). Is there any other way to make the mesh more densy around the airfoil? Because then in fluent i get parts like "fluid shadow" and I think they are messing with my results. Because although i get nice convergence my results are fully wrong.
Thanks for every answer because I'm getting confused..
Maybe one more question? How acurate can the tetra mesh + inflation layer be? Because with an structured mesh i got accuracy about 5% to air tunnel results(Cl), and this highly satisfying for me. But what about tetra?
Hi
I the same problem How did you resolve it
Thanks
baditlm is offline   Reply With Quote
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[ICEM] Why do I have to convert my mesh to an unstructured mesh? iznish ANSYS Meshing & Geometry 1 November 2, 2012 09:29
[ICEM] Just started unstructured mesh ! diamondx ANSYS Meshing & Geometry 6 September 5, 2012 08:15
[ICEM] Extruded unstructured mesh association with boundaries, volumes, etc. macfly ANSYS Meshing & Geometry 6 August 7, 2012 17:13
Improve Mesh quality - airfoil simulation Lukas84 STAR-CCM+ 4 July 6, 2010 11:07
