January 15, 2013, 10:16 |
#61 |
January 15, 2013, 10:45 |
#62 | |
Ghazlani M. Ali
Rep Power: 29 |
Also in the screenshot that you showed us, the prism were generated after the surface meshingand without the volume mesh. if you generete the volume mesh then the prism i'm sure you will get a better looking prism layers. why ? i don't know |
January 15, 2013, 14:39 |
#73 |
Rep Power: 20 |
Far and Diamondx....generating one prism layer and then splitting it to further parts is not a good idea as it produces bad quality prisms(again told to me by Simon). Instead generate atleast three layers and then split them but this splitting operation is not designed to give you good quality rather it is there to save time as splitting operation takes less time than generating the same no. of layers in the initial mesh and also to get your desired wall y+.
Anyhow the procedure is....Edit Mesh>Split Prisms....here there are two options to split prisms i.e Fixed initail height and Unifrom ratio, first will option will ensure the fixed height of 1st layer and later will ensure the unifrom distribution of prisms. After this you can go to Move Nodes>Redistribute Prisms...here again there are two options i.e Fixed Initial height and Uniform ratio. This option redistribute the splitted layers to give you a nice growing and properly distributed mesh in the B.L |
January 16, 2013, 06:29 |
#74 |
AB
Rep Power: 22 |
All those tricks are explained in the ICEM tips and tricks document made by Simon, aren't they ?
There are some posts about the right procedure to create prism on this forum (again based on Simon's tricks and tips ). The way I have always used is this one : 1) surface mesh (patch dependent if your geometry is good enough, otherwise, patch independent by volume mesh then delete volume mesh). Don't forget the build topology 2) smooth until nothing the quality is good : very important to have a good volume mesh after and good prisms 3) volume mesh (delaunay AF+TGLIB) 4) smooth until nothing the quality is good SAVE your project. Then you go for prism : 1) try to create as many layers as you want and see if it works. if not, try the option explains and the Simon's tips and tricks document 2) if it doesn't work, try what CFD Seeker said. you can try one prism layer splitted in as many you want, or 3 prisms layers then split. It depends on how many prism layers you want. If you want only 5 prism layers, just create 1 and split it in 5 after. If you want 20 prism layers, then create 5 and split it after would be a better way. |
January 16, 2013, 10:37 |
#75 |
Simon Pereira
Rep Power: 47 |
Sorry I have been so busy lately... Far emailed me and asked me to stick my head in, but this thread has moved a long way since then. I noticed 2 questions.
1) Yes, if you have some surfaces meshed with patch conforming before you run Octree, you can keep the patch conforming mesh... It is an option when you compute mesh. Change the pull down to "geometry and mesh" and select the parts where you want to keep the mesh. 2) If you assign prism to a surface, like that tire, it will stair step off as it approaches the edge. It does this to prevent a solution where you have all the prisms ending along one plane, particularly very thin prisms with pyramids sticking out into the tetra volume. The best solution is to include the side surfaces in your prism selection. Then prism will be full on the surface you want and will taper off on the adjacent surface.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
January 16, 2013, 11:12 |
#76 | |
Rep Power: 20 |
January 16, 2013, 12:27 |
#78 |
Ghazlani M. Ali
Rep Power: 29 |
@ cfd seeker, i came to lab i realized i flushed away the mesh i had sorry about that.
the stair step is a normal and it happen because the prisms have to end somewhere. if the surface with the prism is really important to you, you can add prism to surface next to it too so you extend where the stair step appear... |
January 16, 2013, 16:17 |
#80 | ||
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 19, 2023 00:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 08:21 |
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 | prashanthreddyh | ANSYS Meshing & Geometry | 1 | December 20, 2011 01:35 |
[ICEM] Hexa meshing blocking problem | fergal | ANSYS Meshing & Geometry | 0 | June 28, 2011 11:01 |
Strange ANSYS Meshing 13.0 Problem | brunob | ANSYS Meshing & Geometry | 3 | June 21, 2011 21:03 |
