#41 | |
Rep Power: 20 ![]() |
#42 |
progress upto now. Surface mesh of full wheel completed. Danualy mesh generated.
Facing problems in prism generation (tried both pre and post inflation) . Always get the pyramids. Any idea how to avoid pyramids? (Already tried prism quality to 0.0001) Should I use Tgrid now? ![]() ![]() ![]() ![]() ![]() ![]() |
#43 | |
However you can first use the octree and delete the volume mesh. Delete the unwanted surface mesh and recreate surface mesh with pd method and fill the volume with denauly. |
#44 | |
![]() Far and scipy....tell me seriously who is boy and who is girl among you people ![]() |
#45 | |
![]() ![]() Any input for the prism mesh generation in ICEM? |
#46 | ||
Read post # 16(By Simon) This is what I got from it but I can be wrong in my understanding |
#47 | ||
#48 | |
#49 | |
#50 | ||
#51 |
Ghazlani M. Ali
Rep Power: 29 ![]() |
FAR you remember the geometry i told you about
https://dl.dropbox.com/u/35161486/problem_ali.tin specially this tubes, can you apply surface meshing on them : ![]() |
#55 |
#56 |
Here is problem I am facing in ICEM when I generate the prisms. Any solution to avoid the pyramids and get good looking, well grown, perpendicular prisms.
![]() ![]() ![]() Also surface mesh is changed (quality go down) when volume mesh is generated ![]() Here is the mesh when I generated the prisms+tet+hexcore in Tgrid. Looks good. ![]() ![]() |
#57 |
Strange I thought pryramids to form b/w the thin gaps in the rim region of tire....any how is there a large difference in size on adjacent surfaces where the prisms have low quality?
The quality is all good in T-grid or there are also problems in T-grid? |
#58 | |
Size in the original surface mesh is almost equal on the wheel and road and there is no jump in size at all. Almost of same size. This happens on the both sides of the prism region, while in the T-grid prisms are grown vertically and smoothly. Quality is awesome in T-grid. I know there is method to get the good prisms in ICEM as well, but I dont know what options to choose. Last edited by Far; January 15, 2013 at 09:19. |
#59 | |
Ghazlani M. Ali
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 18, 2023 23:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 | prashanthreddyh | ANSYS Meshing & Geometry | 1 | December 20, 2011 00:35 |
[ICEM] Hexa meshing blocking problem | fergal | ANSYS Meshing & Geometry | 0 | June 28, 2011 10:01 |
Strange ANSYS Meshing 13.0 Problem | brunob | ANSYS Meshing & Geometry | 3 | June 21, 2011 20:03 |
