[DesignModeler] How to make sure that two bodies are really in contact?
Old   December 20, 2012, 19:17
Default How to make sure that two bodies are really in contact?
yahya
yahya is on a distinguished road
Hi all,
If I have two bodies excatly next to each other, how to make sure that they are really in contact, i.e. how to ensure that the two bodies are really in contact with one sharing interface?
And how we can keep two bodies in contact as two separate bodies of one single part, without merging and forming single body? Do I need to keep them as freezing bodies or is there any other method to keep them separated (or sliced)
best regards,
Yahya
yahya is offline   Reply With Quote
Old   December 20, 2012, 21:53
Erik
evcelica is on a distinguished road
Yes you use freeze or add frozen to keep them from merging. To make sure they are in contact, model them that way, but even if they are not in perfect contact you can still apply interfaces between them if you are using CFX (and perhaps other programs too)
evcelica is offline   Reply With Quote
Old   December 20, 2012, 22:01
yahya
Im using Designmodeler to simulate fluent flow
So im NOT using CFX
Old   December 21, 2012, 03:26
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Well you are only using DesignModeler to prepare the geometry. CFX is an example of solver software.
You can make sure that they are in contact by unfreezing them. If the bodies merge into one, they are in contact. Then you can delete the unfreeze from the outline tree
jrunsten is offline   Reply With Quote
Old   December 21, 2012, 05:06
yahya
Thanks jrunsten for your help
One last thing does it matter if the body if freezing or active
When i go to the next step (meshing and simulation) i.e. there is no problem
Of keeping the bodies frozen?
Old   December 21, 2012, 05:08
Josef Runsten
You can have them frozen or not, it does not matter in meshing
compiling firefoam Farshad_Noravesh OpenFOAM 27 December 24, 2012 05:21
Arbitrary rigid bodies in coarse grid DrummerB Main CFD Forum 8 April 26, 2012 11:09
Ansys Workbench contact problem! JoelHenrik ANSYS 1 October 1, 2010 15:57
make a chart in CFX-POST Alessandro CFX 1 March 4, 2008 17:24
[Q]How to make MPEGs with CFD datas??? Bum-Seok Hyun Main CFD Forum 4 February 16, 2000 19:59
