[DesignModeler] 3D Cubical Enclosure in DesignModeler-Can't Define Fluid Volume |
December 6, 2012, 15:10 |
Mike
Rep Power: 14 |
Greetings All:
I am aiming to model natural convection of a fluid inside a cube with hot and cold walls. In DesignModeler, I made a rectangle out of sketch, made a surface and swept it to make a 3D cube. Once I meshed it and solved it, I don't see any solved solution for the interior! It seems the Fluent did not recognize the volume. Please advise. Thank you |
December 6, 2012, 16:41 |
Mike
Rep Power: 14 |
Using Workbench, I used DM for designing and its own Meshing tool. Any advise?
December 6, 2012, 16:57 |
Ghazlani M. Ali
Rep Power: 29 |
what do you mean by solved solution in the interior ? when you created your volume in designmodeler, it has a name the default one is "SOLID", can you see it in fluent ??? do you have cells inside it
December 7, 2012, 17:56 |
3D enclosure to study the fluid inside-Problem of design
Mike
Rep Power: 14 |
Dear All:
Let me rephrase my question in a better order. The goal is to model a cube which includes 6 walls obviously and filled with a fluid, lets say air. Something like a room with walls and inside air. The idea is to investigate the natural convection of air inside the room when we have hot and cold walls. In Design modeler, it looks like I can not model the volume correctly. The reason is that once I solved my problem, I do not see any variable solution like temperature and velocity for inside fluid (air). There is no option of interior fluid. Am I missing a step in defining my volume? I used cube option from primitive 3D DM. Please help me how can I solve the issue to study the fluid inside. Thank you |
3d enclosure, designmodeler |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 10:08 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
