December 5, 2012, 21:40 |
Aneurysm + Stent Meshing !
Rep Power: 14 |
I need some advice. As part of my research our lab focuses on virtual stenting and coiling in patient specific aneurysms. We have traditionally used ICEM CFD to mesh the aneurysm geometry and deployed stent geometry but the problem is it is difficult to resolve the stent geometry without creating a crazy amount of elements. We volume mesh both the aneurysm and stent geometry, then import the mesh into Star-CD, then delete the "shell" elements that represent the stent so we can perform CFD. Can anyone think of a better way of doing this?? Does ICEM CFD have some type of Embedded mesh technique or Immersed Boundary that can be used to resolve the stent meshing issue? Another problem is that since the stent is quite small compared to the parent vessel, ICEM creates dozens of "CREATED MATERIAL" that I believe represent the small volume gaps between the stent geometry. I've tried importing the volume mesh into CFX, but finding and deleting these "shell" elements like we do in Star-CD is not as cut and dry. Is there an easy way in CFX to distinguish between "shell" and the volume elements so the deletion of the stent is easier??
Sorry for the long response but help is appreciated! |
December 6, 2012, 07:54 |
Christoph
Rep Power: 18 |
I think, we need some pics or geometry (.tin-file).....at least I do
maybe you can use BFC for your project: http://www1.ansys.com/customer/conte...shing%20Module |
December 6, 2012, 13:29 |
Rep Power: 14 |
I attached an image of what I'm talking about. As you can see, the stent geometry is very small compared to the flow domain.
March 22, 2013, 09:19 |
David
Have you considered using a hexacore mesh in the centre and a finer tetrahedral near the walls and stent struts as I assume your only interested in whats happening there.
September 16, 2015, 20:07 |
This may be a long shot but have you solved this problem? I'm working on a problem that is very, very similar and would love to get your input.
May 11, 2016, 13:21 |
Hi, did you get a solution to your stent meshing?
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 12:03 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 06:01 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 12:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 12:08 |
