[ICEM] Simple pipe meshing - problems with y+ in CFX |
December 1, 2012, 15:27 |
#21 |
will 6.7 m/sec make the difference or velocity profile is the main culprit What will happen if I use 10 m/sec?
Did you take care of axis direction? Can you share the velocity profile? |
December 1, 2012, 15:51 |
#22 | ||
2. see this http://www.cfd-online.com/Forums/cfx...-pressure.html If you specify blending factor = 1 then is same as uniform static pressure. I have also used blending factor = 0.05 3. Using from workbench or directly doesn't make difference. Some text from CFX help: Quote:
blending factor = 1 ~ uniform static pressure. Try to use the blending factor = 1.0 and see what happens. Last edited by Far; December 1, 2012 at 16:27. |
December 2, 2012, 17:55 |
#23 |
Rep Power: 14 |
Hi Far,
I have run it again. And it WORKS. In fact, my previous meshes work too (although yours gives better y+, mine have y+ of around 100, but that is a matter of refining, and much better than 150,000!). I am embarrased to admit the mistake I was making. Let's just say it was something very very dumb. I have looked up the blending factor now, sorry, I didn't have the helpfiles when I wrote my previous message. I will try changing it to 1 later, but since things work now it is not a problem. the velocity profile I use is: Wmax*(abs(1-r/Rmax)^0.143) where Wmax=8.197m/s Rmax=20mm and that goes in the W box in the inlet when choosing cartesian velocity components. Thanks so much for all your help. It was this last bit of checking what was different to your simulation that allowed me spot the mistrake. Thank you. K |
January 15, 2015, 09:00 |
#24 |
adelo
Rep Power: 11 |
dear Keizers
so i have work similar to your case (circulair pipe two phase flow), i want to put new wall function in CFX , just you can say that im new in cfx , can you send me your case or simple one to begin. thanks |
icem, inflation, mesh, pipe, y_plus |
[ICEM] Using a hybrid mesh for a simple pipe | Udio_NT | ANSYS Meshing & Geometry | 17 | October 18, 2012 15:42 |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 12, 2012 00:18 |
icoFoam simple pipe wont write pressure | basilwatson | OpenFOAM Running, Solving & CFD | 2 | May 15, 2011 12:04 |
[ANSYS Meshing] meshing quality for CFX | icemaniac178 | ANSYS Meshing & Geometry | 0 | April 23, 2011 21:21 |
CFX problems with supersonic inlet condition - Inlet values in CFX-Post are wrong | jannnesss | CFX | 5 | February 25, 2011 17:24 |
