[ICEM] simplify STL geometry and export it to COMSOL |
November 9, 2012, 06:56 |
Carles
Rep Power: 14 |
Hi everyone,
I would like, one more time, to ask you for help. I´m want to do some simulations of a porous media in COMSOL. My starting point is STL file. It is a quite complex geometry that should be simplified, smoothing edges, .. (I can not import directly the geometry meshed by ICEM due to the lack of a license...) Then after some test seems that the best option is to export the geometry as an IGES file (as a Parasolid file does not work out), but for such purpose I should have bspline lines and surfaces. Does anybody know which is the better way ? I though to build the topology. Then the surface which define the geometry is split. Then create a bspline lines from these surfaces. and points from these lines. And then do the smoothing process manually. I also tried with the " create/modify surface > geometry simplification" tool but it doesn´t seems to help. Any suggestion? doubts about my problem? Thanks, Carles |
November 13, 2012, 09:19 |
Carles
Rep Power: 14 |
Hi Far,
Thanks for your interest. Now I´m learning how to use pro-engineer properly, then I will do the whole geometry again.... |
comsol, geometry, iges, stl |
ICEM-CFD Geometry Export | Francois | CFX | 7 | September 9, 2012 17:22 |
[snappyHexMesh] Mesh a geometry without stl file | eysteinn | OpenFOAM Meshing & Mesh Conversion | 0 | May 5, 2011 11:15 |
[ANSYS Meshing] TurboGrid export geometry after meshing | la7low | ANSYS Meshing & Geometry | 0 | January 13, 2011 20:50 |
Export geometry in workbench from simulation. | kezman | ANSYS Meshing & Geometry | 1 | October 14, 2009 15:06 |
Importing I-DEAS unv file | hbetb | FLUENT | 1 | August 10, 2001 14:22 |
