[Other] Rotating cylinders in Ansys
Old   November 2, 2012, 09:29
Default Rotating cylinders in Ansys
Casper Petersen
CasperPetersen is on a distinguished road
I realize this might be a simple question, but so far the "solutions" i've managed to track down on the net does not work. Granted I dont know if this is possible (though it would strike me as odd if this was the case).
After opening Ansys, select Preprocessor (Ansus 14 btw) -> Modeling -> Create -> Volumes -> Cylinder -> Solid Cylinder. Fill in WP X = 0, WP Y = 0, Radius 0.25, Depth = 2.
This creates a solid cylinder of the specified dimensions along the Z-axis. My question is: how do I rotate this cylinder 90 degrees around the positive y-axis only? As another example: Given this initial cylinderA , how do I create another cylinder B that is perpendicular to A? How do I rotate cylinders in Ansys?
Thanks in advance
CasperPetersen is offline   Reply With Quote
Old   November 2, 2012, 09:35
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
use create -> body operation -> type rotate ...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   November 2, 2012, 09:47
Casper Petersen
Thanks for the reply. I dont have that option in Ansys. It seems thats a command associated with the work bench? Is it only possible to carry out the rotation in Workbench as opposed to the Software Suite?
Old   November 2, 2012, 10:32
diamondx's Avatar
Ghazlani M. Ali
what software are you using ??
Regards,
Ali
Old   November 2, 2012, 10:38
Casper Petersen
Ansys 14.0. I think the software suite that I accidentally referred to is the more commonly known Ansys Classic, where you get the legacy Ansys GUI with the work space taking up 60% of the screen and the Preferences, Preprocessor, Solution, General Postproc etc are located to the left. Please bare with me. I've only been at this for 7 hours.
However, if the solvers used by workbench and classic are the same, am I right in saying I could just as well use workbench where, according to you, the rotation will be possible?
Old   November 2, 2012, 10:56
diamondx's Avatar
Ghazlani M. Ali
I was talking about ANSYS design modeler available in workbench I'm not familiar with the classic ANSYS...
Regards,
Ali
Old   November 2, 2012, 11:02
Casper Petersen
Oh, the body operation is in the work bench. I would just like to know if the same rotation is available in classic.
Old   November 2, 2012, 11:26
diamondx's Avatar
Ghazlani M. Ali
i have no idea, sorry
Regards,
Ali
ansys, cylinder, geometry, rotating
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
Rotating cylinders rathish FLUENT 8 June 22, 2010 18:22
Rotating cylinders peterchen FLUENT 0 June 21, 2010 04:44
Rotating coaxial cylinders Xiana FLUENT 0 May 28, 2007 11:33
PROBLEMS WITH ROTATING FLOW BETWEEN TWO CYLINDERS vitmalin CFX 2 October 11, 2006 08:22
