[ANSYS Meshing] Non Sweepable bodies
Like Tree4Likes
Old   January 28, 2013, 09:19
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Originally Posted by b.shuvayan View Post
HI.
But I am trying this new problem where everything is same..
Unfortunatly this is a way more complicated geometry than the sphere you started with. I don't see how you can get a full hex mesh of this using Ansys Meshing without an extreme ammount of geomtry splitting.
I'd go for ICEM Hexa
jrunsten is offline   Reply With Quote
Old   March 23, 2015, 07:41
Dr. Moloy Kumar Banerjee
moloykb is on a distinguished road
Dear Jrunsten
I am doing the same geometry, where a sphere is there inside the cube , but I have to mesh the both. According to your guideline I have meshed the cube part other than sphere and next is how to mesh the sphere (preferable sweep mesh)
moloykb is offline   Reply With Quote
Old   February 1, 2018, 07:28
et.one is on a distinguished road
Hi jrunsten,
I have got this geometry [https://ibb.co/dZW8Jm ].
I separately split the cylinders and the bottom of the chamber (restrictions + long channel) which result sweepable.
Unfortunately the central part and the above hemisphere I am trying in any way but I cannot make them sweepable. Do you have any suggestion?
Regards,
Ernesto
et.one is offline   Reply With Quote
ansys meshing, cfx, sweep
[ANSYS Meshing] sweepable bodies & meshing sandy_1982 ANSYS Meshing & Geometry 6 November 1, 2012 09:04
[ANSYS Meshing] Identical meshes in symmetric bodies in multibody part. aarvay ANSYS Meshing & Geometry 2 May 11, 2012 12:15
Arbitrary rigid bodies in coarse grid DrummerB Main CFD Forum 8 April 26, 2012 11:09
Shared surface between bodies for better meshing? alxe ANSYS Meshing & Geometry 5 August 18, 2011 12:52
Connect two bodies? noramat OpenFOAM 1 September 21, 2010 07:47
