[ICEM] contruction of 2D tin file from Pro_Engineer |
October 29, 2012, 04:34 |
Hyun
Hi all CFD online user
I've been using ICEM by using Pro_Engineer, 3rd party drawing tool, to build 3D .tin file to load into ICEM. I want to know how to build 2D .tin file from Pro_Engineer. Geometry functions in ICEM is very difficult to use, and this is the reason why I want to use pro_Engineer. Thank you all. |
October 29, 2012, 23:57 |
#3 | |
Hyun
Thank you for your reply, I was able to generate 3D structure(STEP file) as you indicated. When I open a new file to draw 2D part, which 'type' option do I need to select such as part, drawing, and sketch? I was able to make 3D STEP file by dwaring part with 'Part' type option, but error message I faced when I tried to draw 2D geometry because 2D geometry doesn't have the thickness. Thank you |
2d tin, icem, pro_engineer |
GPU Linear Solvers for OpenFOAM | gocarts | OpenFOAM Announcements from Other Sources | 37 | August 17, 2022 15:22 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 05:59 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
