[ICEM] How to create a uniform triangular mesh with specified number of nodes in ICEM 13.0?
Old   October 29, 2012, 03:43
Default How to create a uniform triangular mesh with specified number of nodes in ICEM 13.0?
bzz77 is on a distinguished road
Hi everyone:
I'm pretty new to ICEM CFD (version 13.0). I have had no problem creating quite complex meshes, but cannot figure out how to make this simple one (described below) for testing some code.
I have made a rectangular surface. I would like to mesh it with triangles. The triangles all need to be the same size (uniform mesh). The long dimension of the mesh should have 101 nodes and 100 triangles. It does not matter how many layers of triangles are present in the short dimension (as long as there are at least five).
I cannot figure out how to do this.
In "Curve mesh setup" under the "Mesh" menu, it is possible to select the top and bottom curves and specify a number of nodes. I did this and then selected "remesh attached surfaces." But the mesh created is not uniform and there are not 101 nodes along each curve.
If anyone could provide any help, I would be very grateful.
Last edited by bzz77; October 29, 2012 at 07:29. Reason: Clarified language because I wasn't getting responses.
bzz77 is offline   Reply With Quote
Old   November 5, 2012, 15:08
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You need to use one of the patch conforming surface methods. You could try the all tri method, or you could try a quad method and force mapped meshing, then you could edit mesh to convert quad to tri...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
mesh, mesh control, node density
Free jet simulation msarkar OpenFOAM Running, Solving & CFD 39 May 11, 2021 14:21
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
