October 24, 2012, 12:12 |
How to block this?
Rep Power: 20 |
I am trying to block the wing but got stuck in the middle. I know how to block a simple wing with O-grid and C-grid but this wing has a special feature that it has a slot on the wing tip near the leading edge region which is giving me trouble to block the wing tip region. Blowing will be done from this slot in the tip region, so this portion needs extra mesh density and needs to be put in the separate block I guess. Kindly give me suggestions how to tackle slot on the wing tip while blocking. Thanks
Regards |
October 25, 2012, 14:31 |
Christoph
Rep Power: 18 |
wow, that one was really difficult. you need c-grid (far field), o-grid and y-grid (leading+trailing edge) and two other o-grids for the slot.
but i finally got the right blocking approach. you've to adjust some edges to get reasoable angles, but that should be a work of some minutes. sorry, but don't have the time to do this. good luck Last edited by energy382; October 25, 2012 at 16:00. |
October 25, 2012, 20:28 |
Ghazlani M. Ali
Rep Power: 29 |
cfd seeker, if you are wondering how energy382 did it, take a look at this thread, it will help you a lot:
http://www.cfd-online.com/Forums/ans...ic-trough.html The same approach was used, or may be slightly different. am i wrong christoph ?? |
October 26, 2012, 00:44 |
#4 | |
October 26, 2012, 04:20 |
Rep Power: 20 |
Thanks alot guys thank you very much energy,diamondx and far. Its a long long weekend and damn I don't have Ansys in home to check this blocking but thanks alot energy for your effort
October 26, 2012, 05:57 |
#6 | |
Christoph
Rep Power: 18 |
Sorry, I haven't seen this thread yet. But in my opinion, one of the most important thing is to work with the index, to stay on top of things.
So if I do my ogrid or y-grid on the wing, I use index and just display required blocks. What I'm trying to say is, that it's very important to have a well-structured working method (at least if you've to deal with several c-grids, o-grids and y-grids). Not until then (at the end), I adjust the outer edges with "move vertex" functions (to improve cell angles, det. etc) Maybe, I could do a video about my working method if required. Quote:
November 1, 2012, 02:46 |
Rep Power: 20 |
I checked the blocking but there are so many cuts, the things in wing tip region are all messed up and it is very difficult for me to undestand. energy382 can you kindly explain me step by step procedure how you did it or kindly post a pic of every step if possible....
November 1, 2012, 03:46 |
November 1, 2012, 09:35 |
#9 | |
Rep Power: 20 |
Time for the Simon to come into action |
November 1, 2012, 09:42 |
#10 | |
Actually I am busy with family and teaching thermodynamics II course. Now I have free time. I will try... |
November 1, 2012, 10:09 |
#11 | ||
Rep Power: 20 |
November 1, 2012, 13:56 |
#12 |
Ghazlani M. Ali
Rep Power: 29 |
this my try, since i don't have time i blocked only the wing, i'm not sure if it will get you a good quality:
i'm sure there is a better alternative to the y-grids behind, christoph's method is way better than this one. If you want an idea on the blocking i used: |
November 2, 2012, 05:58 |
#13 |
Rep Power: 20 |
Thanks but you didn't take care of slot on the wingtip, the O-grid you put is crossing the slot which is not needed instead slot needs to be put in the separate block. Actually slot is creating trouble otherwise its very easy to block a simple wing using C-grid or O-grid
November 2, 2012, 09:50 |
#15 | |
Rep Power: 20 |
November 2, 2012, 12:40 |
#17 |
Rep Power: 20 |
November 2, 2012, 13:36 |
#18 |
Ghazlani M. Ali
Rep Power: 29 |
energy382's method is difficult... i tried blocking same way without any success. mine is just an o-grid. and using index blocking to filter and split just the block that contains the slot.
November 2, 2012, 13:43 |
#19 |
Rep Power: 20 |
more equation in block matrix system | yhaomin2007 | OpenFOAM | 1 | September 6, 2012 09:33 |
foamLog not solving for Ux, Uy, Uz | aerospain | OpenFOAM Post-Processing | 5 | April 18, 2012 11:01 |
[ICEM] Quest for seemingly simple Blocking (degenerate block) | la7low | ANSYS Meshing & Geometry | 0 | July 12, 2011 20:48 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 03:58 |
blockMesh: block with 6 vertexes | dani | OpenFOAM | 3 | June 25, 2009 14:13 |
