[ICEM] How to block this?
Like Tree2Likes
Old   November 2, 2012, 13:49
cfd seeker is on a distinguished road
So here you used two O-grids?
cfd seeker is offline   Reply With Quote
Old   November 2, 2012, 13:57
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
yes... i used two o-grid !!!
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   November 2, 2012, 14:01
BTW what is the need of two Y-blocks? can't single Y-block do the trick?
Old   November 2, 2012, 14:25
diamondx's Avatar
Ghazlani M. Ali
may be it can. i was in a hurry when i did it... what you can basically do is go to other thread that talks about blocking a wing geometry and apply the best topology for the trailing edge.
My main focus was the slot...
Regards,
Ali
Old   November 22, 2012, 10:33
Christoph
energy382 is on a distinguished road
I've another blocking approach in mind (a more efficient). I've some time tomorrow, to look at your geometry. Or have you already achieved satistfying results?
Originally Posted by cfd seeker View Post
I checked the blocking but there are so many cuts, the things in wing tip region are all messed up and it is very difficult for me to undestand. energy382 can you kindly explain me step by step procedure how you did it or kindly post a pic of every step if possible....
energy382 is offline   Reply With Quote
more equation in block matrix system yhaomin2007 OpenFOAM 1 September 6, 2012 09:33
foamLog not solving for Ux, Uy, Uz aerospain OpenFOAM Post-Processing 5 April 18, 2012 11:01
[ICEM] Quest for seemingly simple Blocking (degenerate block) la7low ANSYS Meshing & Geometry 0 July 12, 2011 20:48
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 03:58
blockMesh: block with 6 vertexes dani OpenFOAM 3 June 25, 2009 14:13
