[ICEM] how to create internal wall?
Old   October 22, 2012, 03:38
Rong Yue
yuhehuan is on a distinguished road
Hi, Far. I saw you have finished the prim mesh in this geometry. Don't you mind sharing the method to generate prim mesh? And I have another question. I defined the 3 orginal outlets as 3 interfaces in fluent and creat the mesh interface. The interface zone 1 is interface 1,2 and the interface zone 2 is interface 3. Finally, the problem of the assigned intefaces have been solved. But when I ran the calculation, the error is: divergence detected in AMG solver: pressure correction. I tried to reduce the UDF, but it didn't work. Do you know the reason? And you told me to record the result from the extended outlets to original outlets, Could you give me some detailed information about this method, please? I will appreciate your help! Thank you so so much!
Regards,
Rong
Originally Posted by Far View Post
I think you should extended your surface with some built-in command or manually (create 5 or more additional surfaces) and start the meshing process from Ab initio. No need to create the internal wall, this function is used when you have wall inside the domain and there is fluid on both sides of this wall. Which is not the case with you.
you are mixing up internal wall with interior.
yuhehuan is offline   Reply With Quote
Old   October 22, 2012, 09:59
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
It is really simple.
1. I just set the global mesh parameters.
2. Prism mesh parameters
3. In part mesh panel, tick the prism mesh for part, for which you want to grow the prism
4. In compute mesh panel >>>> volume mesh >>>>>>> select the prism mesh option as well and then compute mesh
Far is offline   Reply With Quote
Old   October 22, 2012, 11:47
Rong Yue
Could you send me the project file? Because I did according to your setps but I failed. Thanks a lot!
Old   October 24, 2012, 16:09
Far
Sijal
prism with tetra project files
https://dl.dropbox.com/u/68746918/In...etriangles.rar
Old   October 31, 2012, 13:30
Rong Yue
Regards!
[ANSYS Meshing] Remove Internal wall matteoL ANSYS Meshing & Geometry 2 November 30, 2011 05:45
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
