[ICEM] merge surface mesh
Old   October 17, 2012, 08:11
Default merge surface mesh
hadrien calmet
hadrien51 is on a distinguished road
Hi Guys
I have a new problem.
I have a good stl and I want to merge some surface mesh with this stl to close the domain and use the total surface mesh to do a delaunay mesh. I send a picture.
I was looking for in edit mesh > merge nodes but I don't found nothing.
If you have a idea to do it ?
Thanks
hadrien51 is offline   Reply With Quote
Old   October 18, 2012, 15:58
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You may be looking for the stitch edges command...
But an easier way to do it (assuming the purple surface is a mesh, or after you convert it to a mesh using Edit => Facets to Mesh) would be to close holes... Select one of the edges and flood fill (hot key "l") to select the others, then MMB.
Best regards,
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   October 19, 2012, 07:58
hadrien calmet
Hi PSYMN
I try to close holes using edit mesh > repair mesh > Flood fill/make consistent
there is 2 option flood fill and make volume mesh ....
I suppose that I have to toggle on flood fill
you write "Select one of the edges and flood fill (hot key "l") to select the others, then MMB."
but if I select only flood fill I can't select nothing
and If I select both (flood fill and make volume....) I can select elements not edges and the key "i" doesn't work
and last question what means MMB ?
Sorry PSYMM, so many questions
thank a lots
Old   October 19, 2012, 15:01
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
MMB = middle mouse button...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   October 19, 2012, 16:07
hadrien calmet
middle mouse button
of course !!!!!!!!!
thank shine on crazy diamondx !!!!!!!
Old   October 19, 2012, 23:41
PSYMN's Avatar
Simon Pereira
I didn't mean to use the "Flood fill" command. you should use the "Repair => Mesh From Edges" Then select a single edge and then hit the hotkey "l" for flood fill. You could also pick flood fill from the selection tool box.
Best regards,
Simon
Old   October 22, 2012, 06:24
hadrien calmet
thanks
It s work !
thank you guys !!!!!!
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
