[ICEM] Meshing strategy for 3D sharp point
Like Tree8Likes
Old   October 14, 2012, 04:00
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Can you show it with pics? because I am not getting the concept of four blocks. There are initially seven blocks. One is solid, two are in parallel to solid block and touching the cone, two other blocks are on top of these two blocks and other two blocks are in the front domain.
D-willism likes this.
Far is offline   Reply With Quote
Old   October 15, 2012, 07:03
Fan Derrick He
D-willism is on a distinguished road
I mean get rid of those two blocks that touch the cone. Only keep 4 blocks, 2 in the front and 2 at the back. make those 2 blocks at the back larger enough so that they can take the place of those block that touch the cone and keep the original domain shape. Thank you
Best Regards
D-willism
D-willism is offline   Reply With Quote
Old   October 15, 2012, 07:06
Far
Sijal
Best Regards
D-willism
No. Because on these two blocks we are applying the Y-Grid. May be this is possible with circular domain
Old   May 14, 2020, 16:55
Default Quality for O-Grids
  #24
aunmhd is on a distinguished road
please see these five files, containing five steps from the creating the initial block to the final mesh. Quality is around 0.8 and min angle is 18
Hello Far,
I am facing a similar issue with a slightly more complex problem, image attached. Can you kindly suggest how to improve quality on this one? I am getting negative values of determinants in only one of the six quarter o-grids I have made for the streamline body on which the props are mounted.
aunmhd is offline   Reply With Quote
Meshing issue in sharp edges Moti Siemens 7 June 1, 2012 13:40
How to mesh the 1st grid point? Daniel Main CFD Forum 1 October 8, 2007 03:27
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 12:09
meshing a sharp edge line CFX 2 November 2, 2002 12:19
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
