[ANSYS Meshing] Match control at interface between two separate geometries
Like Tree55Likes
Old   November 15, 2017, 23:08
Wink
  #41
Abdulaziz Abutunis
ama294 is on a distinguished road
Originally Posted by PSYMN View Post
The point of having a rotational domain is that it should be free to move and not be con-formal with the stationary domain.
Now, if you want to make the rotating domain into a stationary domain, then yes, you can merge one domain with another using merge mesh or merge blocking (depending on the type of mesh you have). But when you take that mesh to your solver, it will not be able to rotate the domain anymore.
Hi, Simon
Happy to see your reply. Just one question, what should be the surface between rotating and stationary domains set to? is it interior or interface when selecting BC in ICEM?
Thank you in advance!
Aziz
ama294 is offline   Reply With Quote
Old   July 4, 2018, 14:00
amroune
BARKAT is on a distinguished road
how mesh connectivity between the interface
thanks
BARKAT is offline   Reply With Quote
Old   July 19, 2018, 06:51
Maheen Rana
mahi55 is on a distinguished road
Hello, I know it's an old thread. But I really need a solution to my problem here. I have a geometry of outer stationary cylinder(15 cm) and Inner cylinder containing rotor structure(7.5 cm) at a plane 0.4 cm above from bottom of outer stationary cylinder. I find no problem while defining the interfaces which are (top, bottom and side) but an issue is that when I look for velocity contour in a vertical plane there's a discrete change in velocity at interface. I don't know how can I solve the issue. Is it something related to meshing or setup?
I'm using ANSYS CFX 18.0
looking forward for help.
mahi55 is offline   Reply With Quote
control, interface, match, mesh
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Match Control and Symmetry Boundary Condtions in a quasi 2D calculation peterputer ANSYS Meshing & Geometry 0 May 15, 2012 09:53
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
