Ghazlani M. Ali
Rep Power: 29 ![]() |
Good morning,
the picture below represent my square surface with a hole in the middle. The hole is there because a tube passes through them. (fins of heat exchanger) ![]() After i find a solution to my problem on how to mesh that. I still want to make sure if the build topology was correctly done or not. In the picture the edges appears in blue which is good. surfaces of fins are meeting with surface of tube. When i make a hundreds of those fins. some of them appears in yellow. actually half in yellow and half in blue. i'm sure that the surface in designmodler are meeting and a joint is created there. is it a bug in icem, when i mesh , the mesh apperas good. do i have to worry ? |
AB
Rep Power: 22 ![]() |
Make sur that elements are not overlapping around those curves.
But maybe your min mesh element is enough high to avoid troubles there. |
[ICEM] Multiple fluide zone in ICEM Hexa Block problem | ddqp | ANSYS Meshing & Geometry | 4 | October 9, 2013 10:57 |
ICEM boundary condition problem | Martin_D | ANSYS Meshing & Geometry | 2 | February 14, 2011 10:20 |
problem exporting from icem to fluent | jc_muaddib | FLUENT | 1 | June 16, 2010 04:16 |
Icem Cfd To Cfx B.C. Problem | Kordou | CFX | 4 | July 17, 2008 12:49 |
Urgent problem - orthotropic material in ICEM | Luk | CFX | 6 | August 30, 2006 08:06 |
