[ICEM] Extracting Surface from Volume mesh
Old   September 20, 2012, 11:51
Default Extracting Surface from Volume mesh
Joh
Joh
Joh is on a distinguished road
Hey everyone,
I'm trying out FSI for the first time by trying to simulate an elastic pipe. Ive generated a simple unstructured mesh with the volume mesh listed under Fluid and the surface mesh listed under Inlet, Outlet and Wall. The aim is to use the solid mesh for the transient structural modeler and both the fluid and solid mesh in CFX. I was wondering how to extract the solid mesh from ICEM and import it directly into the Finite Element Modeller?
Regards,
Joh
Joh is offline   Reply With Quote
Old   April 20, 2016, 18:10
Default Have you solved your problem?
Haomin Yuan
yhaomin2007 is on a distinguished road
I am trying to do the same thing. If you know how to do it, could you tell me?
Thanks
yhaomin2007 is offline   Reply With Quote
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[ICEM] volume mesh leaking out of the surface, in a multi zone problem premchandpendota ANSYS Meshing & Geometry 6 July 31, 2012 02:36
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
