[ANSYS Meshing] Error in Workbench "Unable to attach to geometry file" |
March 18, 2014, 01:11 |
#21 |
Johnson Jose
Rep Power: 12 |
I made a simple cube in design moduler and saved it.
when taking mesh it starts and goes away automatically and then a x mark in mesh. error is "Unable to attach to geometry file" I tried cad configuration and also even reinstalled ansys still the issue is there... |
May 12, 2015, 17:25 |
#22 | |
Rep Power: 11 |
June 17, 2015, 16:29 |
Same problem, different user
#23 | |
Rachel
Rep Power: 12 |
Attached is a photo of this. I read somewhere that if your "SYS.mechdb" is showing a file size of 20kB (which mine is) then that means it's corrupted ( http://xansys.org/forum/viewtopic.php?p=91606 ), and found step by step how to reload it ( http://www.padtinc.com/blog/the-focu...ble-to-recover )... But I just tried that and I got the "Failed to load legacy database" error in the Ansys main window. Also I would rather PREVENT the corruption, especially when using built in DesignModeler!! For the record: I am not getting corrupted databases after "hardclosing" Ansys. It is within the same Ansys session, from when I create the geometry in DesignModeler, open the mechanical Model to perform meshing and loads, then closing Model, and opening it again. |
June 17, 2015, 19:56 |
#24 |
Rep Power: 14 |
Hi rbgamblin,
Try to use a simple model and see if its working. Did you change location from default when you where installing Ansys? I think its not able to locate your model and thats why giving error. Try re-installing? Cheers KAPI |
June 18, 2015, 05:37 |
#25 | |
Max
Rep Power: 11 |
I've created my Geometry by scripting in DesignModeler. When I run the Script, DesignModeler opens and the geometry creates. When I close DesignModeler it shows the green hook after Geometry in my Workbench. So it should have created the Geometry correctly. When I now want to open Mechanical it shows me the following Error: Code:
CommandFailedException: Geometry must be attached before branches can be created. In file "Z:\Diplomarbeit_HTW\MATLAB\einfache_Zahngeometrie\Running_Script.wbjn", line 2944 Edit: I just found this Code in the "DSGeometryScript.js: Code:
var pmdlg; var kUpdateFromCAD = 0; var kUpdateAllCADParameters = 1; var kUpdateChangedCADParameters = 2; var bIgnoreToolbarUpdate = false; var errorAttachCallback; var warningAttachCallback; /* START OF ATTACH METHODS */ // this funtion is sitting here just because other funtions here using it, already moved to C++: Jay 06/03/07 function progressAttachPane (filename, caption) { pmdlg = CreateActiveXObject (str_WBHTMLDialogProgId); var xf = CreateActiveXObject(str_DlgArgsProgId); xf ("wb") = wb; xf ("dlg") = pmdlg; xf ("WBScript") = WBScript; var coordinates= wb.GetNthFileName(str_SaveProgressWndCoord, "DSApplet"); pmdlg.InitialWindowPosition = coordinates; pmdlg.DoDialog (wb.hWnd, filename, xf, true, 400, 150, 0, caption, true); pmdlg.SolutionDlg = true; } function SpecificAttach (PIName, fName, existingBranch) { try { if(typeof(existingBranch) == "undefined") { g_UIHandler.GeometryHandler.SpecificAttach0(PIName, fName); RefreshMeshingOptionsPane(); } else g_UIHandler.GeometryHandler.SpecificAttach(PIName, fName, existingBranch); } catch(e) { return e.number; } return 0; } function doPlugInEasyAttach() { SpecificAttach("", ""); } function FileEasyAttach(fName) { SpecificAttach(fName, ""); } function doAttachAssembly() { WBScript.Out (localString("ID_DoAttachAssemblyMessage"), true ); } /* END OF ATTACH METHODS */ Code:
function FileEasyAttach(fName) { SpecificAttach(fName, ""); } Best regards Max Last edited by USER1234; June 18, 2015 at 06:39. |
June 18, 2015, 06:28 |
#26 |
Piyush Aras
Rep Power: 11 |
I also faced same problems. But ansys workbench accepts format iges only..
so just save ur model in iges format and then import it will definetely work. |
June 19, 2015, 05:17 |
#27 |
Max
Rep Power: 11 |
June 23, 2015, 20:28 |
#28 |
Rep Power: 14 |
Hi Guys,
I suggest re-installing and checking if it is working! If it is still not working, I reckon you should contact Customer support cuz it could be a bug. Cheers KAPI |
June 26, 2015, 05:07 |
#29 |
Max
Rep Power: 11 |
ok, I figured out that the problem isn't the Mechanical .. I've entered a new Material (Engineering Data) by scripting.
When I use a given material (Engineering Data) everything works fine .. so I have to find the failure in my Engineering Data - script. There has to be a mistake or something missing .. |
June 28, 2015, 19:51 |
#30 |
Rep Power: 14 |
Hi Max,
Share your script so that we can figure out the issue. Cheers KAPI |
June 29, 2015, 00:40 |
#31 |
manan
Rep Power: 11 |
Any one else have module for learning ansys ,I want it bcoz I m student of master of science and wan a use it in my proj.so
June 30, 2015, 07:21 |
#32 |
Max
Rep Power: 11 |
This is my whole script for delete the "Structural Steel" and create a new material "31CrMoV9".
data is in some cases just an example value. Code:
EngineeringData1 = system1.GetContainer(ComponentName="Engineering Data") StrucSteel = EngineeringData1.GetMaterial(Name="Structural Steel") StrucSteel.Delete() NewMaterial_31CrMoV9 = EngineeringData1.CreateMaterial(Name="31CrMoV9") DensProperty = NewMaterial_31CrMoV9.CreateProperty(Name="Density") DensProperty = NewMaterial_31CrMoV9.GetProperty(Name="Density") newData1 = {"Temperature": ["20 [C]"],"Density": ["7730 [kg m^-3]"]} DensProperty.SetData(SheetName="Density", Data = newData1) ThermExpProperty = NewMaterial_31CrMoV9.CreateProperty(Name="Coefficient of Thermal Expansion",Definition="Secant",Behavior="Isotropic") ThermExpProperty = NewMaterial_31CrMoV9.GetProperty(Name="Coefficient of Thermal Expansion") ThermExpProperty.SetData(SheetName="Coefficient of Thermal Expansion",SheetQualifiers={"Definition": "Secant", "Behavior": "Isotropic"}, Index=-1,Variables=["Coefficient of Thermal Expansion"],Values=[["1.2E-05 [C^-1]"]]) ThermExpProperty.SetData(SheetName="Reference Temperature",SheetQualifiers={"Definition": "Secant", "Behavior": "Isotropic"}, Index=-1,Variables=["Reference Temperature"],Values=[["20 [C]"]]) ElastProperty = NewMaterial_31CrMoV9.CreateProperty(Name="Elasticity",Behavior="Isotropic") ElastProperty.SetData(Variables="Young's Modulus",Values="2.1e5 [MPa]") ElastProperty.SetData(Variables="Poisson's Ratio",Values="0.3") AlternStressMeanStress = NewMaterial_31CrMoV9.CreateProperty(Name="Alternating Stress",Definition="Mean Stress") AlternStressMeanStress = NewMaterial_31CrMoV9.GetProperty(Name="Alternating Stress") AlternStressMeanStress.SetQualifier(Qualifier="Interpolation",Value="Log-Log") AlternStressMeanStress.BeginBatchUpdate() AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=-1,Variables=["Mean Stress"],Values=[["0 [Pa]"]]) AlternStressMeanStress.EndBatchUpdate() AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Variables=["Cycles"],Values=[["10"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Variables=["Alternating Stress"],Values=[["3999000000 [Pa]"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=-1,Variables=["Mean Stress", "Cycles"],Values=[["0 [Pa]"], ["20"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=1,Variables=["Alternating Stress"],Values=[["2827000000 [Pa]"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=-1,Variables=["Mean Stress", "Cycles"],Values=[["0 [Pa]"], ["50"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=2,Variables=["Alternating Stress"],Values=[["1896000000 [Pa]"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=-1,Variables=["Mean Stress", "Cycles"],Values=[["0 [Pa]"], ["100"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=3,Variables=["Alternating Stress"],Values=[["1413000000 [Pa]"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=-1,Variables=["Mean Stress", "Cycles"],Values=[["0 [Pa]"], ["200"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=4,Variables=["Alternating Stress"],Values=[["1069000000 [Pa]"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=-1,Variables=["Mean Stress", "Cycles"],Values=[["0 [Pa]"], ["2000"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=5,Variables=["Alternating Stress"],Values=[["441000000 [Pa]"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=-1,Variables=["Mean Stress", "Cycles"],Values=[["0 [Pa]"], ["10000"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=6,Variables=["Alternating Stress"],Values=[["262000000 [Pa]"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=-1,Variables=["Mean Stress", "Cycles"],Values=[["0 [Pa]"], ["20000"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=7,Variables=["Alternating Stress"],Values=[["214000000 [Pa]"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=-1,Variables=["Mean Stress", "Cycles"],Values=[["0 [Pa]"], ["100000"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=8,Variables=["Alternating Stress"],Values=[["138000000 [Pa]"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=-1,Variables=["Mean Stress", "Cycles"],Values=[["0 [Pa]"], ["200000"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=9,Variables=["Alternating Stress"],Values=[["114000000 [Pa]"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=-1,Variables=["Mean Stress", "Cycles"],Values=[["0 [Pa]"], ["1000000"]]) AlternStressMeanStress.SetData(SheetName="Alternating Stress",SheetQualifiers={"Definition": "Mean Stress", "Interpolation": "Log-Log"}, Index=10,Variables=["Alternating Stress"],Values=[["86200000 [Pa]"]]) StrainLifeParam = NewMaterial_31CrMoV9.CreateProperty(Name="Strain-Life Parameters") StrainLifeParam.SetData(Index=-1,Variables=["Strength Coefficient"],Values=[["920000000 [Pa]"]]) StrainLifeParam.SetData(Variables=["Strength Exponent"],Values=[["-0.106"]]) StrainLifeParam.SetData(Variables=["Ductility Coefficient"],Values=[["0.213"]]) StrainLifeParam.SetData(Variables=["Ductility Exponent"],Values=[["-0.47"]]) StrainLifeParam.SetData(Variables=["Cyclic Strength Coefficient"],Values=[["1000000000 [Pa]"]]) StrainLifeParam.SetData(Variables=["Cyclic Strain Hardening Exponent"],Values=[["0.2"]]) TensYieldStrProperty = NewMaterial_31CrMoV9.CreateProperty(Name="Tensile Yield Strength") TensYieldStrProperty.SetData(Variables="Tensile Yield Strength",Values="650 [MPa]") CompYieldStrProperty = NewMaterial_31CrMoV9.CreateProperty(Name="Compressive Yield Strength") CompYieldStrProperty.SetData(Variables="Compressive Yield Strength",Values="650 [MPa]") TensUltStrProperty = NewMaterial_31CrMoV9.CreateProperty(Name="Tensile Ultimate Strength") TensUltStrProperty.SetData(Variables="Tensile Ultimate Strength",Values="850 [MPa]") CompUltStrProperty = NewMaterial_31CrMoV9.CreateProperty(Name="Compressive Ultimate Strength") CompUltStrProperty.SetData(Variables="Compressive Ultimate Strength",Values="0 [MPa]") Best regards, Max |
June 30, 2015, 07:34 |
#33 |
manan
Rep Power: 11 |
I want to analysis of wind turbine by CFD if u have any program for understand it then pls send me on :Mananpatel1991@yahoo.com
July 7, 2015, 09:38 |
#34 |
Max
Rep Power: 11 |
July 7, 2015, 20:01 |
#35 |
Rep Power: 14 |
Hi Max,
Add below code with your previous code and see if it works! Code:
# encoding: utf-8 SetScriptVersion(Version="15.0") template1 = GetTemplate(TemplateName="Engineering Data") system1 = template1.CreateSystem() EngineeringData1 = system1.GetContainer(ComponentName="Engineering Data") EngineeringData1.Edit() StrucSteel = EngineeringData1.GetMaterial(Name="Structural Steel") StrucSteel.Delete() NewMaterial_31CrMoV9 = EngineeringData1.CreateMaterial(Name="31CrMoV9") .... ... ... Cheers KAPI |
July 7, 2015, 23:49 |
#36 |
manan
Rep Power: 11 |
Kapi have you any code which can help me to make a thermal analysis of engine fins or heat exchanger or any elements ,for master thesis
July 8, 2015, 01:26 |
#37 |
Rep Power: 14 |
Hi Manan,
Can I suggest you to start another thread with your question. Posting random question in random thread is not very useful. Start a new thread and ask your question giving all the details you have so everyone can help you in your thesis! Cheers KAPI |
July 9, 2015, 06:42 |
#38 | |
Max
Rep Power: 11 |
I now tried this: 1. open ANSYS Workbench > static structural > engineering data > library > new material 2. enter properties and save it (D:/Temp/31CrMoV9 3. close ANSYS and open again 4. ANSYS Workbench > static structural > engineering data > library > bottom "..." = add an existing data source from file" > chose this file which was generated seconds before 5. Error (I've added a screenshot below) Do you have a suggestion? Best regards Max |
July 9, 2015, 10:26 |
#39 |
Max
Rep Power: 11 |
ok, I figured that problem out .. this one is working now .. but after several testing I realized, that I get a blue question mark infront of the Geometry in ANSYS Mechanical (from Workbench) even if I change the material to a listed material like Copper Alloy. I can change material manually (following several different tutorials) and get the same problem. Does anybody had a problem like this before or do I have to save the changed material again in some different way?
July 9, 2015, 22:21 |
#40 |
Rep Power: 14 |
Hi Max,
One of the reason for the blue question mark could be that you have not defined the full property of material. To choose new Material from the data bank use this code. Code:
#Material Selection #Accesing the Engineering data and modifying the Material engineeringData1 = system1.GetContainer(ComponentName="Engineering Data") matl1 = engineeringData1.GetMaterial(Name="Structural Steel") matl1.Delete() favorites1 = EngData.LoadFavoriteItems() library2 = EngData.OpenLibrary( Name="General Materials", Source="General_Materials.xml") matl2 = engineeringData1.ImportMaterial( Name="Aluminum Alloy", Source="General_Materials.xml") #End of Material Selection Cheers KAPI |
error, workbench |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 10:23 |
Workbench geometry in to ICEM | KM | CFX | 2 | December 21, 2007 14:45 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 05:31 |
workbench geometry in ICEM | Ross | CFX | 6 | November 2, 2006 07:51 |
Virtual/Real geometry. | Jack Keays | FLUENT | 9 | June 16, 2000 00:39 |
