[ICEM] Blocking topology for cruciform fins
Like Tree10Likes
Old   September 5, 2012, 09:15
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by siw View Post
One can either 'see' topologies or not; no matter how much practice is tried (e.g. me)
Each time you try, you always learn more. I must say, I have learnt (95%) from this forum by solving the problems of CFD-Online fellows with the help/guidance of Simon.
Far is offline   Reply With Quote
Old   September 5, 2012, 11:59
Far
Sijal
can you share your original geometry (on forum or privately) or some example geometry very similar to your case so that we can try and discuss new blocking strategies.
Old   September 6, 2012, 05:55
siw
Stuart
siw will become famous soon enough
Far, I cannot share or descibe in detail the geometry (even privately) as it is commerically sensitive.
However, do you recall the generic missile shape you made a topic about (Meshing of complex shape) and due to the 1/4 geometrical symmetry you did the blocking for that? Also, if I remember correctly it had fins near the nose and tail. That can be used but without any symmetry.
If the usual experts could show the recommended blocking for Far's generic missile shape with the cruciform fins (no symmetry planes) - for different types of fin trailing edge shapes (sharp and blunt). Then that would going very far towards what I'm trying to work towards and then I can adapt it from there for my specific case and learn a great deal.
siw is offline   Reply With Quote
[ICEM] Blocking topology for pipe flow with a butterfly valve siw ANSYS Meshing & Geometry 13 November 27, 2012 13:07
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 04:13
[ICEM] Blocking topology for a missile siw ANSYS Meshing & Geometry 1 June 19, 2012 09:30
[ICEM] Blocking strategy BrolY ANSYS Meshing & Geometry 0 July 22, 2010 05:46
[Gridgen] Blocking topology for blunt wing siw Main CFD Forum 3 July 21, 2010 14:55
