September 1, 2012, 13:00 |
Problem with Prisms
Rep Power: 14 |
Hi all,
I am doing a tetra/prism mesh. I have a high quality tetra volume mesh using Delaunay with no elements under a 0.2 quality and a mesh expansion ratio under 20. Yet when I insert the prism layer it goes preety crazy, mesh expansion ratio jumps to 100 and stays very high regardless of smoothing. I have fiddled around with the prism properties but have to no avail found the problem. Could someone please help? Regards, Andris |
September 2, 2012, 11:59 |
Stuart Buckingham
Rep Power: 26 |
Andris,
For all CFD purposes, it is most efficient to have very high aspect ratio prisms. If you think about the velocity gradients, the biggest one is in the direction normal to the wall, therefore this is where you want to have your smallest Δx (cell edge length). If you also have large velocity gradients parallel to the wall, you must capture these using surface sizings before you inflate the prisms. |
September 3, 2012, 04:47 |
Rep Power: 14 |
Hi Stuart,
I don't quite understand what you are saying. I understand that the velocity change is highest near the wall due to the no-slip condition and that is why I am putting prisms with the tetra-hedral mesh. And I understand that they should have a good aspect ratio as the computation of these volumes greatly influences the result. My methodology was to have a tetra-mesh of very good quality before inserting the prisms. Are you suggesting that I smooth this tera mesh even further to get a better prism structure by decreasing the cell edge length when I do Laplacian smoothing? Many Thanks for your help, Regards, Andris |
September 3, 2012, 06:30 |
Stuart Buckingham
Rep Power: 26 |
Andris, near the surface, the velocity gradient is in one direction only, normal to the wall, so this is the only direction that you need lots of resolution. Therefore having high aspect ratio prisms is fine. I have attached a (generic) picture of what I think is a good boundary layer mesh.
Source:http://www.smr.ch/local/doc/virtual_aircraft/d2d/user_manual/ar01s03.xhtml |
September 3, 2012, 06:56 |
Stuart
Rep Power: 26 |
stuart23, just out of interest would you not think from those pictures that the difference in area of adjacent cells is too large at the trailing edge point between the last quad and first tri elements? I've always been lead to keep an epansion rate of 1.2 or less.
September 3, 2012, 06:57 |
Rep Power: 14 |
Dear Stuart,
How do I get these high aspect ratio prisms? All I'm doing is selecting the layers, choosing an exponential expansion and floating the inital height. Many Thanks, Regards, Andris |
September 3, 2012, 07:10 |
Stuart Buckingham
Rep Power: 26 |
@siw: i tend to agree.
It depends on the Re of the simulation to the size of the boundary layer, however I think that the last layer of prisms are too big, and it would have been better to switch to tets sooner. Meshes with a smooth transition between prism and tet are more accurate, and I think that the last layer of prisms are too big for the first layer of tets. It's not practical to solve the boundary layer like this and then have such small tets. The only reason I could maybe think of this is if you are using a hybrid LES model, and therefore need to model eddies away from walls, but this still looks wrong! Having said that, it is still a good example of high aspect ratio prisms, just try not to look at the tets!!!!! Stu |
September 3, 2012, 07:13 |
Stuart Buckingham
Rep Power: 26 |
@Andris, when you inflate your prisms, you can specify them however you want (first layer height / total height / growth rate etc etc), then once you want to smooth, freeze the prisms so they are not smoothed.
Stu |
September 3, 2012, 07:45 |
#9 |
Rep Power: 14 |
Hi Stuart, here are photos of what I have done so far, i' think i am more or less happy with it, but i would appreciate your feedback
Many Thanks, Andris http://www.blog.co.uk/media/photo/1st/6583675#content http://www.blog.co.uk/media/photo/2nd/6583676 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
